Question about Microwave Ovens
How to change light bulb in a Sharp model R-350 L(S) microwave.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
The service manual (available at our site) shows how and shows that the lamp is mounted in the air duct near the magnetron. See http://www.microwavedisplay.com/r510hk_hw_sm.pdf
Part # is RLMPTA086WRZZ and you should be able to get that generically locally but if not, you can get it form Tritronics at http://www.wehaveparts.com
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
  • 82 Answers
SOURCE: Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Posted on Mar 16, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: LIGHT BULB REPLACEMENT
You'll have to unplug it and remove the outer cover, then the bulb is located in a holder in the cooling duct attached to the magnetron on the right side of the unit.
We have a similar service / repair manual for this model and have uploaded it to our site here to help you.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
You can order it ahead of time from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
How do I replace the light bulb in a Sharp R-308KK microwave?
Google the model number with "how to change bulb" and there are some with video instructions on You Tube the Google searches should also bring up.
Nov 07, 2012 | Sharp R-308KK / R-308KW 1100 Watts...
How do i change light bulb in sharp carousel R-320HQ microwave oven?
open cover and
change bulb
before open it turn off woven at last 30 minutes
Jan 30, 2011 | Sharp R-320HQ Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Sharp MICROWAVE CONVECTION R-8465
I fixed it by reading how to fix another model. What you do is take the cover off, the bulb is on top. Make sure that you unplug it before starting.
Jan 12, 2008 | Sharp R-320H Microwave Oven
Microwave Ovens Logo
608 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
