Question about Acer Aspire One Netbook 8.9" Notebook
When i try to connect my laptop with nokia e70 thru blue tooth, it ask for some code, can i know wats that code
    Scholar:
  • 99 Answers
I think you have installed the nokia pc suit on the lap top,
you need to select the option 'add a device'
select bluetooth as the medium and it will as for a passcode, you just need to enter a 2 or more digit number and enter the same on the mobile....
its how pairing of your lap and mobile happens...
(its not some code you don't know its just used for authenticating the mobile or laptop using correctly entered passcode which you select)
its should solve your problem.
Posted on Aug 29, 2010
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
My nokia c7 not connecting to HP pavilion thru bluetooth
Make sure that the blue-tooth is active on the PC and the phone. Now search for devices and when it detects , confirm the passcode and accept the device so as to allow the transfer of files.
Open blue-tooth settings in phone from settings and in PC from blue-tooth manager.
Apr 08, 2011 | HP Computers & Internet
I have downloaded the Blueware software into my pc. Please guide me step by step on how to download the software into my Nokia phone and target phone. Afterthat, how to activate the phones and listen in...
Does your Laptop have Blue tooth or do your the the USB cable for your Nokia Phone?
If you have the Blue tooth power your Blue tooth device on your phone and on your laptop. go to the download software and Right Click on the software and send Via Blue tooth. It may ask for security code or password. choose any digit you like or repeat the digit on one of the device to the other.
The software is sent to your nokia phone as an SMS message. Open the message to install the software.
Dec 20, 2010 | Computers & Internet
My nokia 3230 was unable to perform bluetooth operation
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Nov 25, 2010 | Nokia 3230
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
My bluetooth dosent work in my nokia 6600
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
Take care.
Jun 10, 2010 | Cell Phones
Acer Aspire One Netbook 8.9" Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
