Question about Acer Aspire One PC Notebook
My battery has problem - Acer Aspire One PC Notebook
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 29, 2010
I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
Where do I replace the battery for a cordless mouse that came with my MK300 keyboard
Q: Changing the batteries in my MK300 trnsp.gif 13634.1.0.jpg How do I change the batteries in my MK300?
Wireless Desktop MK300
Model Number:
Y-R0002 (Keyboard)
M-R0006 (Mouse)
trnsp.gif Battery Requirements:
Keyboard:
  • Requires 2 AAA alkaline batteries.
  • Expected battery life is up to 15 months.
Mouse:
  • Requires 2 AA alkaline batteries.
  • Expected battery life is up to 8 months.
Installing New Batteries
Install the batteries for your mouse and keyboard by making sure the batteries face the correct direction as shown in the image below.
Battery Replacement Tips
  • For best battery performance, always use quality alkaline batteries.
  • When replacing batteries, make sure the replacement batteries are new and are within the manufacturer's expiration date.
  • Do not mix old and new batteries.
  • Do not mix batteries of different brands.
  • Do not use rechargeable batteries in this product.
Jul 25, 2010 | Logitech Cordless Mouse
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
