How to add a file to play list? - Computers & Internet
  • 4,889 Answers
It depends on the player you are using. In most players you should right-click on the file that is playing currently and click add-to-playlist. If that doesn't work then please let me know whats the player you are using so that I can provide advice that is specific to that player.
Posted on Aug 29, 2010
Tip
How to Convert MKV files
MKV(Matroska video) is a multimedia container format that can hold a large number of video, audio, picture or subtitle tracks inside a single file. It is intended to serve as a universal format for storing common multimedia content, like movies or TV shows.
Matroska file types are .MKV for video (with subtitles and audio), .MKA for audio-only files and .MKS for subtitles only, .MKV file is the most popular of the tree types.Matroska is similar in concept to other containers like AVI, MP4 or ASF, but different in the way of containing. So many device like iPod, Zune, Xbox, Apple TV, PSP, PS3, iPhone can't play this format of video.
What should I do if I want to Play my favorite movie in MKV format on portable player like iPod and Zune?
The following step-by-step tutorial will show you how to convert MKV files to AVI, MP4, WMV, MOV files, so that you can play on iPod and Zune.
Step 1: Install and run the iSharesoftware MKV Video Converter.
Step 2: Add file. Click "Add File" button on the toolbar to load files.
is-mkv-video-covnerter-1.jpgStep 3: Choose output format
Choose the file, click "Profile" drop-down button to choose the formats you need, then click "Browse" button to choose destination folder for saving output files.
Tips
1. Click ?Play? button on the right bottom of the main interface to preview the video. Click "Snapshot" button to take a snapshot when playing the video.
Step 4: Convert
After choosing the format, you only need to click "Convert" button on the toolbar to complete the task.
is-mkv-video-covnerter-3.jpgTips
1. Choose an after done action from "Actions > After Done" before converting, to define what the program will do after the conversion.
is-mkv-video-covnerter-4.jpg2. When converting, you can click "File > Run Background" button to save CPU resource and do other things at the same time.
is-mkv-video-covnerter-5.jpgMore features
1. Add profiles. iSharesoft MKV Video Converter allows you convert one source file to several different format files at one time to fit your different players.
Select the video to convert, click the "Add Profile" button and choose an output format from the profile drop-down list, then repeat the process to realize outputting several files from the same file.
2. Define output size with Bitrate Calculator
This feature applies when you want to output a file with exact file size.
Select the video to convert, and click "Tools > Bitrate Calculator" dialogue, then the corresponding video bit rate will be calculated automatically. Click "OK", then you will see the output size of the video as you specified in the file list.
3. Set detailed parameter
Click "Advanced Profile Settings" button on the right top of the main interface to set detailed parameters for special needs.
on Mar 22, 2010 | Audio Players & Recorders
How to set the usb port on supersonic sc25 all region dvd player to play mp4 and mkv files
Check the user manual (find one online if you don't have the printed version). It will list the file types that the player can decode and play. If it does not specifically list mp4 or mkv files, you're out of luck. There's no way to add codecs to most DVD players.
Nov 01, 2014 | Supersonic SC25DVD DVD Player
Sir,adding playlist into mediaplayer in vb.net2003
Hi, Some expert will solve this issue soon. Since I m pretty busy I can give you a tip:
Either you could use a temp file or a queue. 1. Creating the play list. 2. Adding / Removing. 3. Saving/ Loading. 3 steps.
You can just use a queue to load items. It has to be expanded in a situation which is the queue is full. You have to work on that. Use a separate thread for the playlist. You may use a queue or a temp file to store the locations temporarily (with specified rows or / and pointers). File operation is slower than a queue. Adding removing items: You can use a file handle to let the user Browse for folder and select one or multiple items. Then store it in the queue or tmp file. If you want to allow drag and drop Check this tutorial and get an idea since its a bit too long process to explain. http://www.dreamincode.net/forums/topic/132491-drag-and-drop-files/
So when you have finished that you have to keep pointers to each file. Use it further to play the file. (To access the file).
Removing files: Remove the pointer and delete the entry in tmp file or update the queued data (or you can ignore that but queue may overflow if it doesn't managed well) To do so you can use another thread but it must not override the playing process. Its very good to have two queues however and that will increase the performance. One for playlist and one for pointers of available items in the play list.
Save and Load: Saving can be done using a file operation easily. When loading the file check for the play list extension. Its better if you could examine other play lists as well (for other players such as Windows media player, KM Player, Real Player etc.) You can have an idea. How ever its very important that to maintain the compatibility with other play lists. If your player can load other formats and if other players could load your format then its optimized.
When you load it use the queue or tmp file. Temp file has to be a text file or similar. Have fun! Reg. Lasitha
May 29, 2010 | Intel Computers & Internet
I want software
you can use windows media player to add songs .open the windows media player.click on the library tab.
you can see the songs in the library now, on the top right hand sideclick on the now playing list, select sync list.drag songs which you require to the list from the library on the left side.click on start sync to send over the songs to your player
Mar 07, 2010 | SanDisk Sansa Clip MP3 Player
I have a camnex mp3 player
When you add files, you have to synchronize the files so they update on the music list.
Jun 09, 2009 | Mach Speed TRIO Onyx MP3 Player
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
I can't add my music or any other type of file to the right place
go to files...nandflash..click...should open up explorer.....scroll down, all your music should be there...once you find your music....click to highlight it....touch the button in the upper right hand corner...the next screen is explorer menu...."add audio to list....once you do this....it will read success....only problem, you have to do it for every song....music goes to music files...once you go to music files..."all songs"....plays your music continuously...
Mar 16, 2009 | Visual Land V-Touch Digital Media Player
How do I make WMP my default player instead of Real Player??
Control Panel -> Add/Remove Programs. Then, on the left, click Set Program
Access and Defaults.
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cant add playlist from memory card
sir u just have to enter track list the go to options > settings then u will get option of auto play or auto play generate u have to turn it on good luck !
Oct 23, 2007 | Samsung SGH-E900 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
