Question about Siemens SpeedStream 4200 (13A4200001) Bridge
How to put in bridge mode - Siemens SpeedStream 4200 (13A4200001) Bridge
  • 398 Answers
Resetting modem to Factory Defaults
Using the tip of a ballpoint pen or unfolded paperclip, press and hold the Reset button located on the bottom of the router. The pwr LED will blink red once, indicating that the reset has begun. Continue depressing the Reset button for four seconds or until the pwr LED begins to blink alternating red-to-green. Release the Reset button.
Set to bridged mode
Should now be on http:\\10.0.0.138 Click “Login” option. The “Username” is admin and the “Password” is admin. Then click “OK”. Click the “Setup” option and then click the “WAN interface” option. If asked for a Username/Password use admin/admin Click under VC heading the “8/35? option. Click “Next>>” The PPPoE option should be selected and then click “Next>>” again. Under the heading “PPPoE Type” select the “Bridge only” option and then click “Next>>”. Click “Finish”
A reboot is required before the new configuration takes effect. Click the word “reboot”. An additional “Reboot” button will be displayed. Click this “Reboot” button”
Posted on Sep 06, 2010
Access to bridge mode
What do you want to know? How to put it into bridge mode or how to get it out of bridge mode?
It depends on what driver you install for this device. The WAN driver gives you PPPoE/A and the LAN driver gives you bridged mode, Dlink appear to have a tool for removing drivers which I see as a very bad sign.
This is a pretty old device - the drivers I'm seeing go back to Windows 98 and Mac OS9...
Apr 05, 2012 | D-Link DSL 200 (DSL-200) Modem
How many watts does this amp put out
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
Feb 19, 2012 | Alpine MRP-M650 Car Audio Amplifier
New to the mixer world. i have a dicontinued pmp5000. can't get the bridge mode to work
You require a special cable with the Speakon copnnector wired a special way. Refer to your user manual for the correct pin connections to use bridged mode and then put the slide switch in the position closest to the effects display.
Refer to figure 4.6 on page 10 and figure 4.7 showing the connection for bridge mode.
NOTE: you cannot go below 8 ohm speaker on the bridge mode... that USUALLY means a singl speaker of 8 ohms... you CANNOT parallel two 8 ohm speakers.
The single speaker cable will plug into the "B" output connector. Remember bothe the barrel and the tip of the connector if using 1/4 inch plugs is HOT and grounding either inadvertently will fry the amp.
Jan 19, 2011 | Behringer Europower Pmp5000 Powered Mixer...
How can u parralel two power amps in stereo?
You CANNOT parallel these amps.
IF THE amps each have BRIDGE mode you can put each in bridge mode for each side of the stereo system. This means one amp to the speaker on one side, the other amp to the speaker on the other side.
NOT ALL amps have bridge mode available.
I won't go into the technical reason you can't parallel the amps other than saying the amps would fight each other with their feedback systems and burn up.
Aug 08, 2010 | Peavey Cs 4080hz Power Amplifier
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
How do I put my Westell modem into bridge mode?
go to IE.
type 192.168.1.254
go to Advance
go to PPP Location
Select bridge mode.
Apr 24, 2010 | Westell Wirespeed LiteLine 6110 Modem
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
Bass boost
yes! just set it to bridge mode connection!
Oct 12, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
222 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
