Question about Apple iPod nano 3rd Generation
Only one earburd working
Only the left earbud works. Purchased new earbuds, same thing.
  • 1 more comment
  • szoober May 13, 2008
    I went to one of the two sites you recommended for a live chat and after asking my question, the answer I received was "wrong site dude-check out www.apple.com." Not the best answer I have ever received to one of my questions.
    The 2nd site that you listed for me to go to (I don't remember the name of it), that was the response I received after I typed in my question. It was a live chat.
  • szoober May 14, 2008
    You are correct about us not having a chat session. It was one of the sites you recommend that I try-that was were I had a chat session and received the response I told you about. Thanks for trying to help.
  • Apple Master
  • 13,433 Answers
The headphone jack might need to be replaced check here
http://store.ifixipodsfast.com/index.php
Posted on May 13, 2008
  • Ekse May 13, 2008
    What? I don't understand, what?
  • Ekse May 13, 2008
    I have no idea what you are talking about, we havent had a chat session. Well I don't know good luck.
The left earbud of my new headphones wont work
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
Oct 28, 2017 | Sony Audio Players & Recorders
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)
I hope this solution was helpful
Oct 17, 2013 | LG HBS-700 Bluetooth Headset
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
Left Earbud Went out randomly
The only thing you can do is to replace it.
Jun 17, 2009 | Sony Audio Players & Recorders
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
I have a problem with earbuds or headphones, when I plug the earbuds in it only plays on my right side of earbuds.
Hey...that's the exaxt same thing that happened to me. On the same side too.
If you've had it for awhile the only thing I can suggest is replace it.
Apr 30, 2009 | Audio Players & Recorders
Left ear going out
Your left ear canal may be plugged. You may have to improvise a way to flush it as you would while taking a shower. Use a cotton swab or equivalent to remove the residue.
As for the earbud, there may be foreign matter lodged inside where it is inaccessible.
If the headphones cannot be repaired, there may be a way to get a replacement expedited to you through one of the support groups.
Jun 20, 2017 | Shure SCL3 Headphones
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Aug 13, 2008 | Skull Candy LINK Earbuds Consumer...
Only one earbud working
Either the connector on the ipod is broken or something more serious
You can try reseting the device
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
heres the apple online service assistant
https://selfsolve.apple.com/GetWarranty.do
May 07, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano 3rd Generation Logo
66 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
