Had the LCD TV For 5 Years, no problems, then just before going to bed i was about to turn off the tv when the screen went black but sound was fine. I switched channels and you could hear the channels changing and sound still ok, turned tv off. Left power to tv on with Sky digital box. Put tv on this morning, still the same. I have now switched everthing off to tv. What could be the problem? Thanks. Dean
  • 4,889 Answers
Your problem can be related to either LCD backlight inverter failure or T-con board failure. Please turn on your tv, darken the room and see if you notice a dull glow on the screen. If you see a dull glow then backlight is functional and the t-con is dead. Otherwise it can be a backlight inverter failure(in some cases the backlight itself). In that case I would try replacing the backlight inverter board and hope its not the backlight as the backlight is embedded into the the panel and the only way to replace it is to replace the panel.
Posted on Aug 29, 2010
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
I have an LG model 37lc2d the screen is black but has illumination and no sound at all and the green power light flashes 16 times upon powering up?
Things to check: Make sure your TV is set to the correct input.
I DK about the light flashing 16 times but that could be a stuck key on your remote control. If you can, urn off your remote and try turning on by hand and going through the "INPUT" choices to make sure you have it on the correct setting. BTW, if your TV is 5 years old, you'll make the money back in no tie if you get a new "Energy Star" TV. The new Energy Star TVs run on very little electricity compared to 5 years ago.
Jul 03, 2012 | LG 37LC2D Television
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Black screen with sound. Problem on every channel.
Sound no picture or shut down Power led starts green then a short amber then turns RED . If your power supply can be confirmed to be go you have a bad Inverter board. Per the manufacture this part comes only with the panel . Not cost effective . But if you go to
lcdparts.net you will locate an inverter for $ 169.99 . I had the same problem and the inverter repaired the set . Note there are similar error codes but from what I can see from all of your complaint I do be leave that your Inverter is bad . Good luk
Chongo
Aug 18, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
