Question about Singer Featherweight II 117
How do I adjust the overthread, it is too loose?
    Genius:
  • 1,788 Answers
If you do not have your manual you can buy one from singerco.com for $15 and it will be a hard cover, I am sure that it is worth it to answer all of your questions. More than likely the problem is in your threading, either tangled thread or thread slipped out of a guide somewhere along the way
Posted on Aug 31, 2010
Straight stitch. Top is fine loose on bottomadjusting top tension does not help how to adjust bottom tension?
Usually, if there are loose threads under the fabric, it is the top thread that is too loose. Check your sewing sample closely--you can even test with two different color threads to help distinguish which thread is which. Loose top thread will generally be pulled DOWN and show under the fabric. Loose bobbin thread will be pulled UP and show on the top of the fabric. The ideal tension is when both threads MEET in the middle of the fabric.
First, remove the thread from the machine. Install a brand new needle. Always Raise the Presser Foot and thread the upper thread, making certain the thread path is correct.
Check that the bobbin thread is threaded correctly and turning the proper direction in the bobbin case.
Set the upper tension to the midway point and sew a retest. A tweaking of upper tension may be necessary to get it where it should be. Generally, upper tension should make the majority of adjustments needed for tension correction. Bobbin tension is one of the last tension adjustments to make as it is very sensitive and can go awry very quickly.
If, in fact, the bobbin tension is off, the tension skrew on the bobbin case is where the adjustment is made. Before making any bobbin tension adjustments, mark where the skrew slot is located on the bobbin case with a permanent marker. This will allow you to reverse your changes if necessary. Be CAREFUL as TINY changes make HUGE differences in tension. Make only 1/8th turn adjustment, then retest before making another adjustment.
Remember that tension testing and readjustment are a necessity when sewing. The same tension that will work with light weight thread and fine fabric will most likely not work when using heavy thread on drapery fabric. Get comfortable with making tension adjustments to get the ideal tension for each project.
Understanding Thread Tension Threads
Oh You Crafty Gal Sewing Lesson 10 How to Fix Tension on Your Sewing...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&ved=0ahUKEwilg-3t2vHMAhVJDlIKHXnsBWYQFgheMA0&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja
How to Adjust the Tension on Sewing Machine
May 24, 2016 | Sewing Machines
How check motor burned up
Loosen the belt and try to see if it will run. If it runs then you need to redo your adjustment. The belt can't be too tight or too loose and it must be perfectly aligned. The best way to do this is remove the top thread. While pushing the foot speed control adjust the belt tighter, more loose and side to side until the motor is at it's maximum speed. Tighten the motor and retry. While doing this be careful!
Feb 16, 2015 | Sewing Machines
How to adjust bobbin tension on Sophia
Check for lint and loose threads in both tension disks and bobbin case.
May 11, 2014 | Husqvarna Sewing Machines
Stitch is to long and loose on brother sq9050
If the stitch is loose you need to adjust the tension, if the stitches are preset you cannot adjust them but you should have various sizes on the machine if electronic
Oct 04, 2013 | Brother CS-6000
Top thread to loose how to adjust
here are 2 free manual for the machine choose which one is correct
for the model, when the top thread is loose you have to adjust the
bobbin tension which should be covered in the manual,, if the
information is not in the manual then the machine would have to
be taken to a repair shop for the adjustment
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Jan 06, 2013 | Brother LS-2125 Mechanical Sewing Machine
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
Loose stitch
change the needle--make sure the needle is the correct one for the fabric
you adjust the top tension for the bobbin thread
Apr 16, 2012 | Sewing Machines
Janome 4623 le bottom tension loose
adjust the top tension up one number at a time & then sew a sample, if it's still loose then increase one more number until you get the desired stitch.
Feb 27, 2012 | Janome 4623 Mechanical Sewing Machine
Lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
May 27, 2010 | Brother Sewing Machines
The threads are not tight on my serger
Here is an easy way to get your thread adjusted. Rethread the machine using four different colors. Then sew and for example the "yellow" thread is loose on the fabric, you know to adjust the tension with the yellow thread. Also a good starting place on your dials is 4-3-2-1 from left to right. Start with the tension set there and then adjust as needed.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Singer Featherweight II 117 Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
