Question about Panasonic Electronics - Others
Hi need play code 3 dvds on panasonic dvd s58 , how can i do this Cheers sheldon
  • 2 more comments
  • sheldonbaile Aug 29, 2010
    Hi unable to acess first method when insert dvd says err
    is there a way by using the set up button on the controler
    2nd method dont have action button on control
    please advise
    cheers
    hi
    I was unable to acess 1st method says err on dvd player . Is there a way using the set up button on the remote. 2nd method i dont have a actionl button on remote
    please advise cheers
    Hi press 8888 after set up nothing happened
    Have on the screen
    System
    language
    audio
    video
    other
    Cheers
    Hi trying to clear regional code on dvd player panasonic s58 please help
    Cheers
  • Panasonic Master
  • 19,396 Answers
Hi.
There is no known region hack for this player (see Panasonic DVD-S58 region.
Unless the player had been purchased region three or unlocked, there is no way to have it on region 3. DVD-S58 is a single region model only! Different units for different regions embed different chips and firmware. Multiregion chips are not available.
To give another example and let you save some of your time, here is a company called multiregionmagic, that modify as many players ar possible. This model is MONOREGION even on their sale. The unit region cannot be changed even in specialized workshops like that.
Take care.
Ginko.
Posted on Aug 29, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please try these methods one by one and it will be unlocked---
Method 1:
INSERT DISK- and confirm "STOP" is displayed...
USING THE REMOTE press "SETUP"
Go to "DISPLAY" menu
Select "ON SCREEN MESSAGES" then press "ENTER" button
Press ">10" found on the bottom right corner
Press "6" button
Press "4" button
Press "3" button
Press "8" button
A PASSWORD WINDOW SHOULD APPEAR
TYPE IN "3192"
PRESS THE "ENTER" BUTTON TWICE
Method 2:
1. Remove DVD/CD from your drive.
2. Press the following keys on your remote: [ACTION] [1] [>=10] [6] [4] [3] [8]
3. A new menu option will appear named other followed by four stars. Use one of the following codes:
3192 -> Multi-Region Enable
3193 -> Macro vision disable
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Aug 29, 2010
    Ok then follow this method---
    1. Turn the DVD player on
    2. Hit Setup on the remote control
    3. Press 8888
    4. Press Next button ( >>| )
    5. "Version" menu should show up on the Screen
    6. Select "Version" menu, select "Region Code" and choose 0 by pressing the down arrow on your remote.
    7. Click Setup to exit
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Dvd s58 how to make it multy zone
hi,
To make your dvd player region free ,you also need a pansonic tv's or home theater's remote. Do the following with the two remote to make you player region free.
The new Panasonic DVD players DVD-S38 & DVD-S58 have a different way of being multizoned. An extra Panasonic remote is required ie: from TV or home theater:
Power On, Tray Open.
Using remote control included press: Audio, 1, 9, 8, 2. Press Subtitle.
Using another Panasonic remote press Pause.
On the remote included, press 0.
'On' will be displayed on the unit.
ok
Apr 11, 2011 | Panasonic Dvd-s58 DVD Player
How do i make my panasonic s58 region 4
Unfortunately, many DVD players are specifically designed for playing Region 1 DVDs only. I was unable to determine whether it's possible to change regions, but I did locate a Firmware Update for you player which may help it perform better:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Home-Players/Drivers-Downloads/model.DVD-S58.D#ts
Jan 12, 2011 | Panasonic Black DVD Player DVDS58
How do i unlock the panasonic dvd-s38 to play all region dvds
In addtion to the S68/S38 remote this hack requires a universal remote configured for the S58/S38 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
Neither the 'Play/Pause' nor 'Frame' buttons on the S58/S38 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S58/S38 remote press Audio, 1, 9, 8, 2, Subtitle
(it is not required but, if the TV is on, it will display the 'no go' icon after each key press - ignore it).
4. Using the other remote press Pause.
5. Using the S38 remote press 0.
If so, the DVD is region-free.
Dec 06, 2010 | Panasonic Dvds38 Dvd Player
Will play commercial dvds but will not play home recorded dvds
The home recorded dvds disc have diffrence finalizing codes,that the Panasonic dvd recorder doesn't share those codes.That why u can't play those home recorded dvds discs.
Oct 24, 2010 | Panasonic DMR-E55 DVD Recorder
Hi trying to clear regional code on dvd player panasonic s58 please advise Cheers
Hi there, the problem with this type of dvd player is that the remote has a pause/play combined button. You need to get yourself a generic remote and program it to use the dvd player, make sure it has a seperate play/pause button. When you have this remote use the following code :
Audio, 1, 9, 8, 2, Subtitle, Pause and then 0
Make sure you have the disc tray open at the time. The screen should display "On" if the code worked correctly.
I hope this helps and thank you for using FixYa
Aug 29, 2010 | Panasonic Electronics - Others
Looking for the regional code for a Panasonic DMR-EZ47V DVD/VCR combo in Australia and a Panasonic DMR-ES30V DVD/VCR combo. Can you please tell me how you put the code in. Thanks
Region codes are preset in the DVD unit. DVDs are encoded with a region code and are only playable if the DVD player is programmed with the same code as the DVD itself. If you want to play Australian DVDs, you will want to use code 4. There are 9 codes. Check below to find out what region each code is for:
http://en.wikipedia.org/wiki/DVD_region_code
You usually may only change a region code 3 times before it becomes permanent. You need to enter the menu-setup options in your DVD player and you'll want to look for "region code".
May 03, 2008 | Televison & Video
Multi regional DVD player?
To my knowledge, yes it is. The Panasonic NV-VP32 will play all DVDs.
However, to be able to view multi region DVDs (PAL/NTSC), the Panasonic NV-VP32 must be connected to a multi system TV (capable of both PAL/NTSC).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Panasonic DVD-S52 DVD Player
How can I unlock my dvd player to play American dvds please?
I have a panasonic DMR-EZ45V which only plays region 2, but some dvds i want are on only on region 1, can it be changed to play both regions?
willc
Oct 26, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
Electronics - Others Logo
479 people viewed this question
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
