Question about Solis Palazzo Espresso Machine
The temperture light flashing also the icon directly to the left is red
  • 1,089 Answers
If you finished descaling the machine is when you usually get these lights. You need to push the water button and then open the steam knob to reprime the pump and flow meter. If the flow meter doesn't spin these lights will not change. That means you have a cloged flow meter and it has to be cleaned.
Posted on Oct 25, 2010
  • Markus Jul 17, 2012
    right on the money this was just what I needed Thanks man ;)
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Drying light flashes after pre wash cycle
check water temperture might be to low might turn the hot water temperture up, water temperture for best wash is 120 degree
Dec 21, 2017 | Hotpoint 18 in. DC27 Slim-Line Built-in...
How do make the flash work?
Good day, click the link below and download manual. hope it will help to your problem.
users manual
thank you.
Jul 26, 2010 | Vivitar ViviCam 8025 Digital Camera
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
How do you use the flash on a vivicam 8025?
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
Jan 17, 2010 | Vivitar ViviCam 8025 Digital Camera
2003 vw beetle Turbo S temperture light turns red
several possabilities , first ned to preasure test cooling system to find if it has a leak or if it was just overheating and purging coolant. another strong chance is the water pump
Mar 15, 2009 | 2003 Volkswagen New Beetle Convertible
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Temperture icon flashes
if the light is blue it just means the car is not at operating temperature yet. let the car warm up before driving. if the light is red and only stays on for seconds check the coolant level. could possibly be a bad level sensor also if the light is red
Oct 18, 2008 | 2003 Volkswagen Beetle TDI
Flash not working
i think your problem is that you are not flipping open the flash... the flash doesnt automatically flip open... and the blinking red icon in the lower left just means that since there isnt enough light, the camera will spend a bit longer to allow more light to enter the lens, hence you need to keep the camera steady and not shake it... hope this helped
May 20, 2008 | Canon PowerShot S5 IS Digital Camera
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Solis Palazzo Espresso Machine Logo
124 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
