Question about Norelco 8140XL Electric Shaver
Where can I get the stems on the motor / gear assembly ( 4222 036 1290) for norelco 8140xl shaver
  • Norelco Master
  • 1,623 Answers
You will find this item at shaveroutlet.com. See link below<br /> <br /> <a rel='nofollow' href="http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html">http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html</a>
Posted on Aug 29, 2010
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
Norelco 8140XL motor gear assembly
You will find partial instruction to disassemble the shaver at the link below. You will also need to remove the gear plate by removing the two screws in the hair chamber. Then just disconnect the wires from the motor by pushing in on the small metal release next to the wires on the motor while pulling on the wires
https://www.youtube.com/watch?v=rGD84BfKxAE&feature=c4-overview&list=UUc_zJiCUI8mpLyYlwCxo8IA
Jun 08, 2013 | Norelco 8140XL Electric Shaver
Norelco 8100 Series Motor/Drive/Gear Assembly
The gear tips are not available from the manufacturer. You will have to replace the whole assembly. Your other option is to but a used model of the same type off of ebay and take the gear stems off of it.
Dec 31, 2011 | Norelco 8151XL Electric Shaver
Will my norelco 8140 xl electric shaver work with the electrical system in Israel (220v) without a converter? Will I need an adapter?
Yes. the charging cord for model 8140XL have a built in voltage converter and can be used with 100-240V
Dec 23, 2010 | Norelco 8140XL Electric Shaver
One of the spindles that drive shaver head has snapped, can this be easily repaired?
For model HQ8150, the item you reqire to replace the broken gear is found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
You will find generaal disassembly instructional video also at shaveroutlet.com. See link below (it's the second video)
http://shaveroutlet.com/video_tutorials
Follow the instuctions in the video, then remove the wires from the motor by pulling on the wires as you puch in on the metal release tab next to them. Remove the two screws near the broken 'spindle' to remove the plastic gear plate. The motor assembly will then come out
Oct 15, 2010 | Philips Philishave HQ8150 Electric Shaver
Why do the plastic drive gears underneath the shaving head keep breaking off? Thisis the third Norelco 8140Xl this happened to.
If this is a repetitive problem for you, there must be a reason. Most likely, the blades are getting jammed and this is causing the tips of the gears to twist off. To prevent this from happening, make sure that you disassemble the shaver heads and thoroughly clean the teeth on a regular basis to prevent them from getting clogged solid. Also, make sure that you are protecting the delicate combs of the shaver head to prevent them from getting damaged. If the comb gets damaged, the teeth on the blade will lodge in it and this can cause the gear tip to break off.
You can replace thesebroken gears. You will find the required part at shaveroutlet.com. See link below
Oct 04, 2010 | Norelco 8140XL Electric Shaver
Norelco 8140XL Electric Shaver Logo
107 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
