Question about Cell Phones
Hi, I brought a Geepas GTP7122 phone few month back .It was properly and I was able to use Pulse dialing When I reset phone It automatically changed to tone dialing ,My telephone exchange not support Tone dialing .Can some helpme pleas
SOURCE: fax tone when i dial someone
Maybe your provider gave you a fax number instead of a cell number. Or quit redialing the same fax number and try some regular ones.
Posted on Jul 25, 2007
SOURCE: There is no dial tone" in LG Internet Cube
i have tried the same thing and the dial tone has failed but i think you might have to have credit on your phone to do it but i'm unsure to cause mine won't work
Posted on Feb 09, 2008
  • 10 Answers
SOURCE: i cannot change the message
try a factory reset but it means you will lose every thing. unless.. you can save all your stuff on your pc
Posted on Apr 22, 2008
  • 3 Answers
SOURCE: pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Posted on Aug 09, 2008
  • 3 Answers
SOURCE: Cordless telephone sw/from pulse to tone
In General Electric (GE):
TONE/PULSE DIALING
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My store had a huge power outage where the lines were sparking. Anyway since the power has come back on I have no ring & can not dial an extention after i dial a phone number. I have looked in the...
So you're saying you can dial a phone number, but when the voicemail system answers you can't dial an extension number ? If that's the case, that means your phone system reset. Generally that means all phones will have access to only line 1 and 2, and that they'll be ringing on all phones. The date would usually change to Jan. 1st 1980, but caller-ID might override that. All line programming would be set to pulse, which would be the cause of you not being able to dial an extension number a voicemail system answers. It would also mean that when you do dial a phone number it takes a while before you hear it ringing. (Because the phone system is dialing in pulse instead of tone, if you stand next to the phone system you'll probably hear it go)
... Long story short, your entire phone system needs to be reprogrammed. I suggest only doing a partial reprogramming, then unplugging the power for a few minutes and check to see if the programming stuck. If not, the battery in your system also needs to be changed.
May 20, 2011 | Nortel Meridian M7208 Corded Phone
I just yesterday replaced a uniden phone when i brought it home i pluged it in at 9 pm and it was left on all night this morning we went out and came back at 2 pm when i looked i had messages and when...
Depending on your model, you can change the dial mode on the handset from pulse to tone through the menu option.
Try pressing the menu button, scroll down to global setup, press select, scroll to dial mode, press select, scroll to tone, press select. You should then get a confirmation beep, and tone dialing with them activiate for your next call. This should allow you access to your voicemail.
Thanks,
Erin @ Uniden
Aug 31, 2010 | Uniden Cell Phones
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
I think you would of already saw it if there is one but it should be on the side or bottom of the phone. Hope it Works
Jan 09, 2007 | GE 26939GE2 Cordless Phone
Cell Phones Logo
111 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
