Question about 3Com 4200 24-Port Ethernet Switch
I forget admin password and security password
    President:
  • 2,185 Answers
There should be a reset button at the back of the switch. While it is turned on, just press a paperclip and hold it until you see that the lights turned off and the switch restarted. That way the old password will be deleted and its like having it fresh from the box.
Posted on Aug 29, 2010
  • poliyadav
    poliyadav Apr 22, 2014
    there is no reset button ,what i suppose to do????
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
I want to install another computer to my wireless access point but I have forgotten my password. Is there any way I can relocate this?
Which password you have forget? if you forget AP admin password then just reset it from rest button on AP. if you have forget security key then just go control panel with admin password and change key.
May 31, 2011 | Computers & Internet
Forgotten password
once you forget your router password the only option you have is to reset it,, unplug your router,, look at it carefully you will see a really small switch called reset Like in this image darklord1_5.jpg
this will reset your router the the day u first brought it..
Log back into your router using the default username and password.. e,g admin/admin,, or admin/
remember you have to set back up your security and everything else as well
Apr 02, 2011 | Computers & Internet
How do I set a password? I've been using this router for years without one... thanks
Connect Wired cable to the linksys Router via PC/Laptop
Go to browser and point to IP address 192.168.1.1 (Can be different if manually changed)
Default username : admin password: admin
Go to Wireless TAB -> Security
Select Security type as WPA2 or WPA (WPA2 preferred)
Select passphrase as YOUR KEY
Make sure to click Apply afterwards.
You have now a password on your SSID.
Mar 12, 2011 | Linksys Wireless-G Broadband Router
I can't locate my WEP key for BEFSR41 router. When I entered 192.168.1.1 it asked for userid and password. I tried 'admin' under each of those lines (leaving other blank) and neither worked....
Hi chrismoore,
Welcome to Fixya. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 06, 2011 | Linksys EtherFast Cable/DSL Router
I forget my yahoo password & also one of my security answer. Now how can i get my yahoo password ? My email id whose password i forget is ankurarora007@yah00.co.in
if you forget also your password security answer, forget it, even yahoo admin dont know the passwords. better to signup a new account
Dec 13, 2010 | Yahoo Computers & Internet
CANNOT SECURE my router
type 192.168.1.1 in your web explorer address bar and if password is prompted type admin admin or refer to the users guide ;)
don't forget to rate :)
Jan 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Blitzz wifi router default userID and password?
The default is admin and admin...
If that doesn't work, the reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address2.gif of 192.168.1.1
The default username and password for your Blitzz router are both "admin".
Don't forget that all your personal settings will be erased as well (wireless security2.gif, port forwarding etc.
Nov 08, 2009 | Blitzz Technology (BWA611) Router
Trying to change the router settings to secure - currently listed as an un secured connection. I tried the address link and prompted with user name and password. I left user name blank and password admin...
If the user name and password doesn't seem to work for you. Press and hold the red reset button on the back of the router for about 5 seconds. This will set it back to the factory defaults, were the blank user name and admin password will work for you. Once you accomplish that, you'll be able to setup your secure connection.
Good Luck,
and don't forget to leave a rating.
Thanks
Mark
Sep 15, 2009 | Linksys WRT160N Wireless Router
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Aug 16, 2009 | D-Link (DWL-2200AP) 802.11g/b Wireless...
3Com 4200 24-Port Ethernet Switch Logo
260 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
