I have a HP 2035 lcd monitor that has a 3cm yellow vertical stripe running though the middle of the screen.
I have smth same... my monitor as gets warm, has a vertical stripe that become blurry, then it becomes worse till the white or black striped, like a zebra line appears? Some electricians have changed the condensators, have put the radiators to reduce the heat, hell knows what is with it, I really like it but no1 can fix it... any1 have any ideas?
Posted on Mar 01, 2011
On my screen I keep seeing red vertical stripes. How do I get rid of this?
You can try to hook up an external monitor. If the vertical linea are visible on the external display, try to update your video card driver. If it is not showing in the external monitor, You are having an LCD problem.
If you don't have any external monitor, go to BIOS setup and check if the lines are visible, if yes, you're having an LCD/screen problem. You need to replace either the LCD cable, LCD inverter or LCD itself.
Hope this helps.
Jul 17, 2011 | HP Pavilion dv4-1020us Notebook PC
Lcd screen getting broken!
you need to replace the LCD panel. go to the HP site and look for a replacement part.
Jun 02, 2009 | HP Compaq nc6320 Notebook
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Yellow stripe in the middle....
Your TV having the main board defective. Any question please call me at 323-767-6030.
Sep 26, 2008 | Astar LTV-3201 32 in. LCD Television
Acer 1711 17"Lcd monitor vertical stripe problem
That's pretty easy; not much is wrong. You have a backlight with several sections to it, and one section has gone dark on you; once you carefully take the monitor apart (on old towels, perhaps) and find the backlight circuits and LEDs or compact fluorescents, clean the dust out and retry; if the dark bit persists, you get to repair the supply power (or replace the lamp) for the center bit. Usually it's an edge-lit light pipe (rigid or woven) that lights your 'stripe.'
If you search on the ODM model number you find once you open the thing up (i.e. on the guts) you might get a hint as to how the supply is set up and save some disassembly/reassembly steps or simply find a replacement balanced light-strip or LED equivalent to swap in. Otherwise test the larger capacitors in service in the backlight power section for warmth through a vinyl glove (having also taken other electrical service safety reviews of your bench, in 3 or more passes, with a friend around, so you don't casually spoil the mostly-working monitor or vital organ.) You could use AC probes to find a leaky cap too. (Probably something 3cm cubed with 6 to 8 like neighbors, natch; though it could be that an upstream component is bad and the center circuit merely the victim among the supplied circuits.)
May 11, 2008 | Acer AL1711 17" LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Monitor problem
My Friend, This one rings like a hardware malfunction with lcd. Try contacting contacting compaq/Hp
Jun 04, 2006 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
