Question about Hammering
How do I swap a grounded electrical outlet for an ungrounded outlet in an old house?
  • 565 Answers
While a lot of people have replaced a lot of 2 prong ungrounded outlets with 3 prong outlets, as you probably know, it is an unsafe practice. The National Electric Code (NEC) permitted method is to replace the 2 prong outlet with a 3 prong GFCI outlet such as this:
http://www.homedepot.com/Electrical-Outlets-Plugs-Outlets/h_d1/N-5yc1vZ1xg4Zbp9i/R-202026815/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
For multiple outlets, the usual practice is to install the GFCI outlet at the first outlet in the circuit, then regular 3 prong outlets can be used to replace 2 prong outlets in all the downstream outlet locations as long as the "no equipment ground" stickers that come with the GFCI outlet are used and they are now GFCI protected outlets, per NEC.
Finding the first outlet in the circuit is not always easy. First, determine which outlets are on the circuit, then starting with the outlet closest to the electric panel, disconnect the wires and see if all the other outlets went out. It's kind of trial and error.
Once you have found that first outlet in the circuit, connect the hot wires coming from the electric panel to the LINE terminals of the GFCI and the wires going to the downstream oulets to the LOAD terminals of the GFCI. Full instructions come with the GFCI outlet.
The GFCI receptacles sold today won't work if connected incorrectly, so you will soon know if you did it wrong.
Once the GFCI outlet is installed at the first outlet, all of the downstream 2 prong outlets can be replaced with 3 prong outlets, using the stickers mentioned above to indicate that the outlets are not grounded.
Strange as it sounds, all downstream outlets _must_ be ungrounded when using this method.
Posted on Aug 30, 2010
Testimonial: "Bob appears to be very knowledgeable, quoting the NEC regs."
When I used grandfathers old table saw with ungrounded cord. It worked fine, I then plugged a jig saw into same outlet. It worked fine. When I laid the jig saw on the table saw there was a spark a
Check the plug that goes into the outlet. On modern plugs, one prong is taller than the other. The taller is the "ground" leg - the other is the "hot" leg. I bet that you just need to flip the plug over so that the other prong is in the "ground". If this works - mark the "ground" leg (or replace the plug with a newer one that has a taller "ground" leg).
Sep 16, 2014 | Saws
My Dell XPS 410 computer will not start, won't do anything.There is however an LED light on the Motherboard labled Stdby Led, this is lighted but the compter won't do anything? I am needing someones...
Your computer power button may not be working, or the CPU may be bad and it can also be the motherboard is faulty.You need a new case or fix the power button or try another CPU in the computer or replace the motherboard.
Aug 16, 2010 | Dell XPS 410 PC Desktop
I have an ungrounded outlet. There is no easy way to ground it conventionally. Close by is a grounded outlet on another circuit. Can I jump a ground wire from the grounded outlet to the ungrounded...
First are you sure the other outlet is actually grounded?
Article 250.130 (C) Non grounding Receptacle Replacement or Branch Circuit extensions.
The equipment grounding conductor of a grounding-type receptacle or a branch-circuit extension shall be permitted to be connect to any of the following.
(1) Any accessible point on the grounding electrode system as described in 250.50
(2) Any accessible pint on the grounding electrode conductor
(3) The equipment grounding terminal bar within the enclosure where the branch circuit for that receptacle or branch circuit originates.
(4) For grounded systems, the grounded service conductor within the service equipment enclosure.
(5) For ungrounded systems, the grounding terminal bar within the service equipment enclosure.
Or you can see 406.3(D) replacing with a ground fault receptacle
Aug 06, 2010 | Hammering
Where does ground wire go
Hi there, If you can give me a little more information, I'd appreciate it. However, I'm going to give it my best shot to see if I can answer what I believe you're looking for. If you're talking about the outlet (receptacle) that you're plugging your appliance into, then the ground (green) wire, or screw on the bottom of the outlet is where you want to connect your third (ground) wire to. If you just have two wires coming off your outlet (receptacle) and can't find the third wire. Then you'd ground or connect a wire to the inside of the box, and then tie with the ground (green) wire coming from the green ground screw on the outlet (receptacle). The problem with house wiring is, a majority of your older houses outlets aren't grounded. If you have a 3-prong outlet, then maybe yours is. But sometimes, people just change these out for convenience purposes. And lastly, if you're talking about the grounded wire in your appliance - look for a green (ground) screw, otherwise you want to connect this to (or around) a metal screw on the inner frame. A majority of your old appliances were never grounded. So bottom line is; your appliance should work with, or without your ground wire. It would be preferable if it was grounded. But for operating purposes, its not. I hope I was able to answer your question for you. If not, feel free to contact me again. Good Luck, Jim
May 21, 2010 | Hobart Food Mixers
Phillips dvr won't power up. Lost power at house
Try hooking it up to another (working) electrical outlet. If that doesn't work, there's several possible problems.
The most likely is that the box was fried when a larger-than-usual current traveled down the line (or even down the coax if lightning struck and your system isn't adequately grounded); the electrical outlet is either pushing too much or too little power; or your house's ground polarity is reversed.
More than likely your box is bad. If you don't know very much about electrical systems, don't go messing with your ground or any outlets without a wall plate.
Dec 26, 2009 | Philips DIRECTV R15
Can ungrounded outlet cause damage to flatscreens?
If ever an energy pike occurs, it would most likely damage the TV for sure. A grounded outlet helps divert power surges to the ground. Sometimes grounded outlets can only handle so much overload, but never 100% guarantee.
Best protection for a flat-screen is a really good surge protector bar. The best ones cost about $100 - $150. Repairing a TV damaged from a power spike would cost about $400 - $600 from a TV repair shop. So, protecting the TV is a good idea considering the cost of repair.
Aug 27, 2009 | LG 42PX3DCV 42 in. Plasma EDTV
WILL NOT RESET
You might be plugging it into an ungrounded outlet. Or if you are plugging it into an outlet that has a ground fault interrupter, and it is THAT that is throwing, then you have a short somewhere.
Jun 21, 2009 | Haier hwr10xc6 Air Conditioner
Zibro P125
The problem is if you do not ground out your unit and it shorts out, it will blow every last part in your system and you will be buying a new part. Also there is a risk of electrical shock. Now to be honest with you. I do not run my window unit on a grounded outlet. But the plug itself has a fuse
Jun 02, 2009 | Heating & Cooling
Electrical
the old outlet or switch do not have "ground" per-say, if the junction box is steel and you have romax (steel jacket) cable. the casing is the ground.
you need a special cutter to cut the jacket, once you do that, you will see a steel wire inside, that is your ground.
if you have the present day 30wire cable (plastic jacket) then the green wire is the ground. it should be grounded on both end, on the switch or outlet and in the breaker box.
Nov 07, 2008 | Leviton 10 Brown Switch Outlet...
Hammering Logo
169 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
