Question about LG Washing Machines
Hi i have an LG WD-80264TP that is not draining water and is not spinning. at this point of teh cycle it is stuck with strange noise and then an error sign.
  • 383 Answers
SOURCE: OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Posted on Nov 26, 2007
  • 135 Answers
SOURCE: ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Posted on Apr 07, 2008
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
  • 33 Answers
SOURCE: LG TROMM noise during spin cycle
Dear Customer,
for ur water not drainin out, please do the the followin checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • n for ur rattling during spin cycle please do the followin checks..
    Please read our safety information before attempting any testing or repairs
    Before working on the washer, unplug the appliance or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
    A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
    The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
    A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
    The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
    Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
    Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
    There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
    • General tips mentioned above
    • Balance the load
    • Level the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
    Please rate this solution.Thank you..
    Posted on Dec 16, 2008
    SOURCE: lg-wm1832cw front loader washer won't spin and drain
    did anyone solve this problem? Mine is doing the same thing... uggh!
    Posted on Aug 03, 2010
    My lg front load washer posted this ER: check the drain and the hose. we checked all the drain. but the machine stopped when it was on SPINNING. the ER POSTING : CHECK THE DRAIN is back
    Water comes out of the drum through a soft corrugated hose, into the filter, out of the filter through another soft corrugated hose into the pump and out of it through the hose that is put to the drain. Have you checked all of these pipes? Sometimes something small can get past the filter and get stuck in the pump. If it is all clear, then perhaps the pump is faulty.
    Aug 03, 2015 | LG Washing Machines
    Smart drive 085
    It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
    Jun 21, 2017 | Fisher and Paykel (IWL12)
    The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
    Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
    Jul 13, 2011 | LG WD-1041WFH Front Load Washer
    LG Washer WD 80490TP, At Spin Cycle not Spinning, seems to,start and then stop takes about a half hour to count down the 8 minutes of cycle, without spinning the clothes. Clothes are still wet
    Pull the bottom panel off (if don't have access to the drain pump) and open the pump. I'll bet it's clogged.
    Washers won't spin if they can't get all the water out...hope this helps.
    Apr 02, 2011 | LG Washing Machines
    Water pump failure?
    The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
    Remove the drain pump and look for any foreign object to be removed.
    Check the drain pump for a failed pump motor.
    LG is pretty.
    Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
    LG WD-3243RHD Front Load Makes grinding, crackling noise
    Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
    Feb 10, 2009 | LG WM2432H Front Load Washing Machine
    LG TROMM washing machine can't open door
    You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
    Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
    If you do not have done anything similar before, then it is better to call the technician.
    Jan 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Water does not drain, strange noise while in spin cycle
    sounds like something is stuck in your drain system. Most likely just in front or even in the pump
    Please check this
    Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
    No longer spinning/loud noise
    Did all the standing water pump out?? If sou you may have broken a drive coupling
    Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    90 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
