Question about Water Heaters
HEATING OK NO HOT WATER - Water Heaters
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Your incoming water supply line is connected to the wrong side of the heater, the supply always goes in the right side of the tank. A broken dip tube will cuase the same problem. Turn the water off, disconect the cold water supply, remove the nipple form the tank and inspect the plastic dip tube. Replace if nessesary. Please clarify the question if this answer is not what you are looking for.
Posted on Aug 29, 2010
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Posted on May 29, 2009
Y plan smart fit is ok on heating only but bangs and expands into expansion tank when on heating and hot water
Does it do this on hot water only ? may be the cylinder stat not shutting off at temperature set.
Oct 18, 2017 | Water Water Heaters
What will happen if I accidentally reverse the hot and cold pipes going into my electric hot water heater during installation?
You should be OK as long as you caught the mistake BEFORE the heating elements heated up. Water will flow from either side so you should be OK as long as you had water in the tank before turning on for any length of time.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_66a56a0239b6ab32
Jul 27, 2015 | Water Water Heaters
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 17, 2014 | Water Heaters
Water not getting hot in electric mode...heating element has been replaced, did not solve the problem.
Check switch and timer working ok also pencil Thermostat in side heating elemnt is ok and is turned up enough to call 4 heat
Sep 16, 2013 | Suburban Gas and Electric Water Heater, 12...
No hot water,central heating is fine
Sounds like the output fitting has melted inside and clogged up the output pipe. These couplings are one way valves to keep water from draining backwards when not in use to keep from burning elements. They are plastic inside. I would turn off water and replace those after a visual inspect if needed.
Feb 20, 2013 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
A trickle of hot water from taps, central heating ok
May 18, 2009 | Water Heaters
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
