Question about Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 skips over labels
My model 2844 does not print consistently. It will print one and skip over a few labels. I am using 4 x 2 (Running in the 2" direction). I am using a thermal gloss material. The labels are pre-printed. Any ideas?
Jason
  • 2 more comments
  • meganacosta Sep 25, 2008
    My printer (same model) does the exact same thing. So far, nothing has seemed to help.
  • janosvida Nov 10, 2008
    I have same problem & I try calibration and nothing problem solving.
  • Anonymous Dec 04, 2008
    can you send the printer manuel to rawand2@yahoo.com
  • Anonymous Mar 24, 2014
    PRINTS BARCODES ON BLANK LABESL DOES NOT PRINT ON LABELS WITH THERMAL LAMINATION
    Problem Solver:
  • 13 Answers
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
Posted on May 08, 2008
I've had this same problem on the TLP2844. We are using 3 x 1 labels to print shelf barcode labels, it prints a few then skips some labels then prints more. The number printed and skipped are not always the same.
What I did was recalibrate the printer. Turn the printer off. Hold Feed button and turn printer on. The printer will begin feeding labels, looking for the gaps. After the calibration is complete a configuration page will print. Press Feed after to return to normal mode.
Hope this helps.
Jason
Posted on Dec 19, 2008
Please send solution and manual to nhchcenter @hotmail.com
Posted on Oct 20, 2008
Please send the maunai to ndlovusn@gmail.com
Posted on Oct 04, 2008
Please can you send the manual of this model Zera TLP 2844 ? at adnanaziz22@hotmail.com
Posted on Jul 01, 2008
My TLP 2742 skips every other label
Skipping every other label is a software template or size format issue. This means your label size in the computer is not set up to match the label size your printing or you have too much text on your label causing it to print out of the bottom margin causing it to skip to the next label.. Very common issue.
We have labels that may help alleviate your problem as well
Labeldomain com
May 01, 2014 | Zebra Eltron TLP 2742 Thermal Label...
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
Print labels created in ms access
first check your driver for zebra 2844 it is compatible with the OS, if it's Ok may be you can find third party software that help us create label
May 13, 2010 | Zebra TLP 2844 Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
2,075 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
