Question about Fisher and Paykel GWL11 Top Load Washer
Wont turn on when press power button power is switch on
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting,Now, are you 100% sure that you have power at you power outlet?Did you check the outlet with a small appliance such as a toaster or hairdryer?If you 100% have power at the power point and you turn it on so the power goes to the machine and it does not light up initially then either your control module is faulty or your drain pump is open circuit.Have you or can you borrow an electrical test meter to test the pump to see if this is the fault?If the fault is not your pump then it will be your control module.There are two reasons why your control module goes faulty.The 1st is, a component your machine is faulty which in turn has made your module faulty and 2nd, The module has become faulty on its own.Please reply on how you would like to proceed and I am sure I can help you.Looking forward to your reply.
Posted on Aug 29, 2010
Blue light comes on then u press remote to switch on tv, but it wont do it. tv wont come on when pressing on button on the remote.
The blue light merely indicates power is getting to the TV. The TV is not turning on because of an open internal fuse or power supply failure.
Apr 26, 2016 | Televison & Video
Dell optiplex mini tower wont turn on
Make sure the power is being supplied from a working source, then check if the switch on the bottom-back of the computer is switched on. If the power button still doesn't work, try holding the button down for 10 seconds. Next, try switching the switch off, unplugging the computer for at least 30 seconds, plugging it back in, switching the switch back on, and pressing the button.
Apr 25, 2014 | Dell Studio Mini-Tower Desktop Computer
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
How do I get My e260 in recovery mode, it wont even come on?
1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. I do not think your model supports the recovery mode but you can try. 1. Press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
Jan 16, 2010 | SanDisk Sansa e260 MP3 Player
The on button wont switch on my laptop
Please try following DIY
1.Remove the battery and press the power button for one minute.
2.again plug in the battery and try to start.
3.open the RAM chamber and refix the RAMs.
Jul 14, 2009 | HP Pavilion dv6000t Notebook
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Mikomi ak-808u keyboard
When you press your power button your system goes to sleep mode as per your system settings. To awake your system just press any key or 'Awake Key' (if its present on your keyboard), then your system will be back. No need to wait.
Thanks
Iqbal
Mar 11, 2008 | Computers & Internet
Phone wont turn on
Bring your phone to a technician to replace your power switch. I think that's the only problem... Good luck... ^_^
Sep 15, 2007 | Samsung SGH-D600 Cellular Phone
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
