Question about LG Washing Machines
My washer keeps stoping on fill cycle then starts to fill up with water again
    Genius:
  • 1,044 Answers
Switch off the machine for sometime and restart. If the problem persists the you have to call service technician to change the control panel.
Posted on Aug 29, 2010
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
    Two common problems for this simptom:
    If water stops filling when you disconnect the washer:
    Change the pressure switch.
    If water keeps coming in after you disconnect the washer:
    Change the water valve.
    GOOD LUCK MY FRIEND
    Aug 30, 2009 | GE Washing Machines
    Water Overflows from washer
    Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
    Aug 18, 2009 | Kenmore Washing Machines
    Why did my LSE7806ACE WASHER STOP FILLING
    Hi…
    If I get you correct, the hot water is not coming into the machine or it is not working at all.
    Let me know
    Thanks
    Smith
    Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
    Washer filles with water but wont change cycles
    start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
    Jul 21, 2009 | Kenmore 22422 Top Load Washer
    Washer fills with water but does not advance to next cycle
    If this is a rotary timer, nudge the timer slightly in it's normal direction of rotation. If the timer keeps going (it might hang up at the next point in the cycle, but nudge it again), I suspect the timer needs to be replaced. They get weak.
    Jan 29, 2009 | Washing Machines
    Washer fills up than starts draining while in wash cycle
    Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
    Phil
    Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    44 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
