Question about Sony Cyber-Shot DSC-P150 Digital Camera
Iam uanble to switch on the camera,if i pess the power button the camera doesn't switch on
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
    President:
  • 2,185 Answers
The battery you've been using might have ran out. Try replacing the batteries with a new ones. Also, try connecting it to your computer using the USB cable and turn it on from there.
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
Tip
A Work Around For Dealing With a Broken Power Switch
Others have had this same problem, the plastic power on/off slider switch eventually breaks (absolutely ridiculous that it happens at all, and I treated mine very gently).
I was going to throw mine out, then remembered that you can power the camera on by holding down the green arrow button (picture viewing button) on the back for two or three seconds. Unfortunately that doesn't seem to work to turn it off, so you just have to set it to power off after two minutes.
Not a great solution, but better than throwing it away, and better than wasting money to have it repaired (if that's even possible).
on Jan 24, 2014 | Fuji FinePix S1000FD Digital Camera
Check engine light
Your bike can run a self diagnostics.
to do this:
key off position
run switch in run position
press and hold trip reset button
turn ignition to on
odometer will start diagnostic
release trip meter button
To cycle through pess trip button
Feb 21, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
I have panasonic video camera during disc finlaization i remove baterry and connect ac then camera hang up even disc ejector not work and on/off switch too
You need to press the "reset" button, It is a tiny button hidden in the plastics, you will need a paper clip to reach it. By removing power, when the machine was working, you have screwed up the camera logic. It doesn't know what is going on, so can't do anything.
Oct 06, 2012 | Cameras
Hellew there i bought a new ipod and i m uanble to edit the files and its says the data is full and i need to delete ....but i m uanble to delete files,.....when i bought the ipod i happd to delete some...
Put your ipod in Disk mode, in this way you will be able to delete de music files manually.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 08, 2011 | Apple iPod nano
Hi I have Acer ravelmate 3260 & Ihave poblem when power on the the switch i dosnt respone unless i pess it many many times (more than 10 times) please any help or solutions?
try to press and hold it for 3 seconds and see if it would power up... if not, then it could be a problem on the power button itself...
Nov 07, 2009 | Acer TravelMate 3260-4874 Notebook
Taking Black and White pictures on a Canon A430
Place the camera in manual mode (M on the dial). Pess the 'Function' button and icons will appear at the right of the screen. Select the second to the last icon, this is the "My Colors" menu. Press the right keypad button until you have selected "BW" for black and white.
Nov 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Pentax optio e10
change the batteries. mine does this when the batteries are almost dead.
Dec 05, 2007 | Pentax Optio E10 Digital Camera
Sony Handycam PC101E Record button/power switch...
there are loose connection of the power switch try to clean the contact of the switch and adjust it...use a pencil eraser only do not use any spray and liquid.....if you cannot put it back don not try open the camera....better go to the qualified and service center....
Aug 10, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Cyber-Shot DSC-P150 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
