Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel changing randomly
I have a sony KV25X5U that is changing channels randomly every 2 or 3 seconds
    Problem Solver:
  • 22 Answers
The channel switch button had a contact to each other... or clean it...
Posted on May 08, 2008
Black rectangle appearing in lower half of screen on 32" Aquos
did you turn off the close caption settings in the set up menu.
Sep 15, 2012 | Televison & Video
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Picture splits into two halves
Change the box it will solve the problem.
Jun 02, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony tv KV25X5U
have to replace the push switches behind the front buttons for channel change, chassis has to come out to repair
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
No sound on random channels
it sounds like you have SAP enabled. Refer to your manual or on screen menu to verify that it is disabled.
Dec 07, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
