Built-in speaker - the driver ACPI \ PNP0800 \ 4 & 305F7111 & 0
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Computers & Internet
ACPI\VEN_HPQ&DEV_0004 driver needed for window 8 hp dv4 3124tx
If this is a Windows 8 upgrade, it's a common problem. First you have to ID the Unknown device in Device Manager with a yellow triange. Take a look at this forum: http://h30434.www3.hp.com/t5/Notebook-Operating-Systems-and-Software/acpi-ven-hpq-amp-dev-0004/td-p/2537553 You can try this software:
Nov 27, 2013 | HP Pavilion dv6000z Notebook
Code-28 driver acpi compliant system
right click on the driver with error and uninstall it. Restart your computer to install the generic drivers. Usually, computers generate their own generic drivers for the hardware parts in your computer. After doing that, update all drivers. You can find the updates in the website of the manufacturer. However, if you would like to get the correct drivers in no time then you can use RadarSync.
David
Mar 02, 2013 | Microsoft Windows 7 Ultimate 32 bit Full...
Speaker troubles
hi,
you can see inside if thats have a peaker built on it..
if have, u must install the drivers for that audio.. you can fight the driver at this site..
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P3C_4100
thanks...More power ...Godbless
Jan 19, 2010 | Dell Dimension 4100 (-JM0TB01) PC Desktop
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Mar 21, 2009 | IBM ThinkPad R32 2658 Notebook
Computer Keeps Shutting Down
I found an article from Microsoft that may answer your question, which I have quoted below. The link to the page is
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/nostandby.mspx
Ifyour computer won't enter standby or hibernation, it may requireupdated drivers. Power management features, especially standby andhibernation, rely on device drivers that support power management inaddition to compatible hardware. Incompatible video drivers preventthese features from working. The built-in VGA driver, for example, is abare-bones driver that doesn't support power management.
If standby and hibernate don't work, install an updated driver for your display adapter.
Tip taken from Microsoft Windows XP Inside Out by Ed Bott and Carl Siechert. Published by Microsoft Press.
First check HPs website for updated drivers for your machine. Look at your drivers from the device manager and note the version numbers, then compare that with the version on the website.
If they are not helpful, you could try to manually update the drivers by finding them in the device manger, right click on each ACPI device (ACPI Lid, ACPI button, etc...) and select update driver.
If no updated ACPI drivers are available, check the power settings in the control panel. Under the 'Advanced' tab, there are options about what you want to happen when you close the lid, and when you press the power button. (Mine both say 'stand by'.)
To sum it all up:
  1. Check the power settings in the Control Panel /Check if it works
  2. Update Video Drivers /Check if it works
3. Update Motherboard and ACPI Drivers /Check if it worksReply with the results, then rate my solution. :)
Feb 21, 2009 | HP Computers & Internet
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
2,008 people viewed this question
David Payne
David Payne
