Question about Canon PIXMA MP160 All-In-One InkJet Printer
My printer is in error.
Dear sir,
now, my printer is in error. That is the Ink absorber is full. According to the manual guide, I have to change the absorber. But I don't know how to change that absorber. Please guide me.
May all be ok in everything!
yours sincerely,
htinlin
  • 1,031 Answers
You did not specify type of printer is that
Posted on May 07, 2008
What does E2 mean??
Error code
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
visit manufacture website for more user manual guide..
Jul 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full so printer wont print
yes, printer wont print and see screen message
Use this method below with your own risk!!
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
Use MPTOOL to reset waste ink absober full on pixma mp160.
Download your Mptool first http://www.ziddu.com/download/8524406/MPTool.rar.html
Download manual guide how to use Mptool on pixma mp160.
http://www.ziddu.com/download/8525856/mp160manualguide.pdf.html
Hope this can help......
Jul 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber full - what do I do
Use this method with your own risk!!
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
Use MPTOOL to reset your mp160 waste ink full
download mptool http://www.ziddu.com/download/8524406/MPTool.rar.html
But before your use MPTOOL get manual guide how to use that MPTOOL
Jul 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Error 8
Dear sir your problem is or E8 mean
Aug 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Sep 29, 2008 | Brother Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
