Question about Lenovo Computers & Internet
Hello I have problem in my battery It is not working more than 5 minute
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
Posted on Aug 29, 2010
    Brigadier General:
  • 10,406 Answers
Batteries do wear out. Buy a replacement battery (look on eBay) or contact Lenovo, to buy an exact replacement.
It takes too much time to turn on
Is the screen off during this time? it might be the batteries Try buying new batteries. I recommend you rechargeable batteries. If it doesn't work try installing the latest firmware from hp.com/calculators
Dec 26, 2011 | HP 50g Graphic Calculator
I have got an HTC wildfire and it run out of battery and now it wont charge or turn on dnt know whether its the battery or the phone it was working perfect
Hello, let it charge from the outlet socket (not pc!) for 5-20 minutes and it will power up again.
Hope it helps.
Jun 08, 2011 | HTC Wildfire Cell Phone
Hello my problem is that the battery just last about 5 minutes even when i let the battery charging all night
sounds to me like you have a bad cell in the battery. i would try a new one. if this is new it may be under warrenty. remember just because somethings new dosent guarentee it works properly. if you get a new battery and the same thing happens it could be a charging problem or short with the chair.. i hope this helps you
Jun 03, 2011 | Pride Mobility Products GoGo Ultra X...
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it...
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Mar 28, 2011 | Kodak EasyShare M1093 IS Digital Camera
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
How do I unlock my camera so I can take pictures?
There are many reasons for this.
But at least you may try this first.
1.Turn off the camera.
2. Remove your battery and memory card.
3. wait at least 3-5 minutes.
4. Insert fresh battery and memory card.
5. Turn on the camera.
6. It should work now.
This is a basic reset for your camera.
Regards.
Apr 26, 2010 | Jazz JDC31 Digital Camera
Hello i have 2001 Mitsubishi montoero sport to day took the battery out and now when i try to start it, it runs for a second or two then goes off
disconnect the battery again, with it disconnected press hold the brake pedal for 30 seconds, leave the battery disconnected for 30 minutes. reconnect battery, turn key from off to on and wait 2 minutes, start the vehicle (don't touch the gas or brake for 5 minutes) this is what I did on my friends montero and it started right up and ran fine, only thing I could figure is that I caused the computer to reset and recalibrate itself, but i'm not real sure. worked for him maybe it will work for you... good luck
Feb 14, 2010 | 2001 Mitsubishi Montero Sport 4WD
Hello, my laptop is a sony vaio ngn fz21s, and I can't turn it on. Since yesterday it doesn't work. I plugged it in differents plugs but still it's not working. The problem is not in the battery cable is...
some time computer does not start if have problem with BIOS. First remove the cover and remove c-mos battery for 5 minutes then try to start the computer.If it dowsnot works then checkup in hardware repair center.
Nov 01, 2009 | Computers & Internet
RESET AIR RIDE CONTROL MODULE RECENTLY INSTALLED
Can you tell me where the control module for a 2004 Navigator is located? I want to find out where all the wire from each airbag solenoid is routed to. I would assume that all go to the control module
Oct 07, 2009 | Lincoln Navigator Cars & Trucks
Computers & Internet Logo
29 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
