Question about Saeco Magic Comfort 103467 Espresso Machine
When I remove the tank for refill, and place it back on the main mashine it leaks. This may have to be repeated several times for it to stop leaking, as if the black joint has a defect valve or rubber packing. How can I fix this
  • gamlejan Aug 29, 2010
    Wery helpfull, but where can I buy the part in europe.
  • Saeco Master
  • 1,711 Answers
The tank valve is consist from small piston and on its adje have a small rubber 'o' ring the piston move with a small spring.
The key in your problem is that finally you can make it stop leaking this mean that everything is in place and not completly damage, however you may still have it a bend spring or psiton and it can not seat in place directly or you may have a scale deposit arount the valve which blocking it from seat in its place. Also the plastic psiton or its base might have tear out so it loose and difficult ot seat in its place from the first time.
So the best solution since this not an expesive part is to replace the valve completly with anew one this will save you time and trouble.
Good luck
Posted on Aug 29, 2010
Saeco xelsis leaking water
The removable drip tray inside the front of the machine has two rubber inserts on the back side and the rubber has come away from the plastic causing a false leak. You will need to order a new one or fix the existing one.
Nov 26, 2013 | Coffee Makers & Espresso Machines
During the replacement of my radiator, the ac line was knocked lose. Do I need to a specialist to refill the freon? I have a 2001 300M
The correct answer is "yes".
The backyard mechanic answer is this:
Reconnect all hoses.
Use a recharge kit with the engine off and just put some pressure back into the system, keeping the Refrigerant can upright. Check for any leaks with soapy water by the repaired connection.
If no leaks, you know have to purge the system. The correct way is to evacuate the air with a vacuum pump. If you don't have that, the alternative is to remove the kit from the charge port. Carefully press in the small pin in the center of the port to open the valve and release all the gas you just charged in. Refill again like you did the first time, DONT run the engine, just let the refrigerant can pressurize the system again. The bleed it off again. Repeat this several times.
Each time you do that, you dilute the air that may have gotten into the system, and increase the percentage of refrigerant vapor. After about four or five times doing this, most of the air and moisture should be removed. Refill the system as described on your refill kit and you should be back in business.
Note: don't this with R-12 gas, it is an environmental hazard, R134a is not.
Dec 26, 2012 | 2001 Chrysler 300M
Slow leak from tank into bowl. We can hear tank refilling once or twice a night.
I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. Edit your post: insert-link-blue._v192249896_.gif To insert a product link use the format: [[ASIN:ASIN product-title]] (What's this?) I'm contractor for the last 17 years and this is the first time I have problems with the toilet tank installation , I bought four toilets, three of them had a leaking tank I thought that the place that had bolt did not have enough pressure and I put more pressure every five minutes but the toilets kept on leaking, I took the bolts out and I put plumbing putty in the top and the bottom and installed it again but it kept on leaking then i removed the putty and i put liquid teflon on the bolts and finally the leaking stoped. cancel-glossy._v192250345_.gif deletepost-glossy._v192250344_.gif Guidelines
Feb 04, 2011 | American Standard Cadet 3 Right Height...
When I remove the tank for refill, and place it back on the main mashine it leaks. This may have to be repeated several times for it to stop leaking, as if the black joint has a defect valve or rubber...
Good luck
Aug 29, 2010 | Saeco Magic Comfort Plus Espresso Machine
How do you replace the fuel pump in a 1997 Ford thunderbird?
Electric Fuel Pump REMOVAL & INSTALLATION Non-Supercharged
  1. Disconnect the negative battery cable and properly relieve the fuel system pressure.
  2. Remove the fuel tank and place it on a bench.
  3. Remove any dirt that has accumulated around the fuel pump retaining flange so it will not enter the tank during pump removal and installation.
  4. Turn the fuel pump locking ring counterclockwise and remove the locking ring.
  5. Remove the fuel pump and bracket assembly. Remove and discard the seal ring. To install:
  6. Clean the fuel pump mounting flange, fuel tank mounting surface and seal ring groove.
  7. Apply a light coating of grease on a new seal ring to hold it in place during assembly and install in the seal ring groove.
  8. Install the fuel pump and bracket assembly carefully to ensure the filter is not damaged. Make sure the locating keys are in the keyways and the seal ring remains in the groove.
  9. Hold the pump assembly in place and install the locking ring finger-tight. Make sure all the locking tabs are under the tank lock ring tabs.
  10. Rotate the locking ring clockwise until the ring is against the stops.
  11. Install the fuel tank in the vehicle. Add a minimum of 10 gallons of fuel to the tank and check for leaks.
  12. Install a suitable fuel pressure gauge on the valve on the fuel rail.
  13. Turn the ignition switch from OFF to ON for 3 seconds. Repeat this procedure 5–10 times until the pressure gauge shows at least 35 psi. Check for fuel leaks.
  14. Remove the pressure gauge, start the engine and check for leaks. prev.gif next.gif
Aug 26, 2010 | 1997 Ford Thunderbird LX
Leaking and refilling
The flapper (the rubber cone shaped piece at the bottom of the overflow tube is not sealing completely. You can purchaser a new one at most hardware stores and replace it yourself. It's an easy DIY fix.
Jun 25, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
How to remove fuel pump on Neon 1998 ? can I reach from inside the vehicle ?
on a dodge neon the fuel pump is in the SIDE of the tank... NOT the top. to remove the pump follow these steps...
******* first unplug battery and remove ********
1. unbolt passenger side tank strap and lower side of tank.
2. a. if tank is plastic, CAREFULLY unscrew plastic retainer ring but do NOT remove.
b. if metal tank, unscrew metal retainer flange but do NOT remove
3. unplug electrical connector and fuel line from pump. move aside.
4. completely remove retainer BE CAREFUL not to disturb pump.
5. have drain pan or wide-shallow bucket available to collect gas. (if tank is full this will need to be able to hold 7-8 gallons)
6. gently twist and pull pump out till gas comes fourth. catch gas in pan/bucket.
7. remove pump when gas stops flowing.
8. install is reverse of removal.
9 BE CAREFUL not to wrinkle gasket or lose gasket into tank when installing or the tank will leak around pump.
10. tighten retainer but DO NOT OVER TIGHTEN.
11. reconnect plug and fuel lines check for leaks.
12. reattach tank strap and fasten
13. refill tank with clean gas. check for leaks.
14. put battery back in. connect battery, start your neon and check for leaks one last time.
15, have fun. this will take about 4hrs to do by yourself with proper tools.
Apr 24, 2010 | 1998 Dodge Neon
Hot water tank leaks, big time, as it refills, stops dripping
If the leak is from the tank itself, no you can not fix it. If it is a supply pipe and the leak is visible, in most cases yes. I would recommend you have this issue resolved very soon. If the tank has sprung a leak, it will be a matter of time before the leak becomes a flood.
Feb 03, 2010 | Plumbing
No pressure when i press break, slight leak under left rear tire,
1st need to know where the leak is? Is it a rusted line, or? To bleed after repairing leak, do the following: Have a helper start the Jeep, go to the wheel the greatest distance from the master cylinder, have helper pump brake pedal 3 times, pushing down about 1/2 way on pedal each time. 3rd time, he should hold pedal at 1/2 way down point while you open bleeder to let air/fluid out. As flow is about to stop, close bleeder. Repeat til all air removed. Check master cyl and refill often, because if you draw in air, you have to start all over. Go to the next wheel that's now the greatest distance from master cyl, repeat, til you get to wheel closest to master cyl. Done!!
Apr 22, 2009 | 1999 Jeep Cherokee
Saeco Magic Comfort 103467 Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
