Question about Bush 2871NTX 28" TV
Bush 28inch widescreen tv
Clicking sound from rear of tv no picture or sound, only a fast clicking noise.
  • 2 more comments
  • Robertidwal May 07, 2008
    help and how much to repair do you think?
  • Anonymous May 24, 2008
    clicking sound from rear of tv no picture or sound fast clicking sound fron rear
  • hotstop May 24, 2008
    yes
  • tony anayoa Aug 03, 2008
    my own have picture but there is no sound
  • Bush Master
  • 19,396 Answers
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
We have no sound on a old style tv (not lcd flat screen) picture is fine its a 28inch bought new 3 years ago
I would refer to the manual and call the manufacture, Or you could take the back panel off and check if the speakers have a solid connection. You can also check the back to see if the tv has speaker hook ups and if it does it might have a switch by it that is for turning surround sound on you need it on stereo or mono.GOOD LUCK HOPE THIS GETS YOU ON THE RIGHT TRACK!!
Dec 23, 2010 | Bush Televison & Video
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Water got into my 28inch widescreen tv
Many circuits operate with millionths (and less) of an ampere and if the set was operated with any residual moisture, it may have destroyed any number of them.
Jan 04, 2009 | Durabrand DWT1905 TV
Pink colour
Hi there!
May be that the colour Amp is at fault or the tube is busy failing. Commonly it would be the colour Amp (Dry joints or faulty drivers). The Green is dead. I have had cases where power surge can magnetise the tube to such an extend that the whole picture will show one colour. In your case I doubt it very much. Good Luck,JUS004
Feb 26, 2008 | Bush WS6671 28" TV
Televison & Video Logo
353 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
