Question about Cisco WLS G BROADBAND RTR-54MB PER SEC W/ 4PT SWCH Router
I want to set up security for a network already established ...
  • 2,263 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Aug 29, 2010
If I reset to default,what will happen?
All settings will return to factory settings. You will need to re-establish your internet connection with your ISP, set up and secure your wireless network, and establish an administrator password. Resetting the device will cause the UserID and password for the router to go back to factory settings. These can be found in the manual
Aug 02, 2014 | Computers & Internet
When i connect to laptop i get connection terminated with error code 734
If you try to establish a Point-to-Point Protocol (PPP) dial-up connection, you may receive the following error message: Error 734: The PPP link control protocol was terminated. As a result, you cannot establish a dial-up connection.
This issue may occur if either of the following conditions are true:
  • Multi-link negotiation is turned on for the single-link connection.
    -or-
  • The dial-up connection security configuration is incorrectly configured to use the Require secured password setting.
To resolve this issue:
  1. Click Start, point to Settings, and then click Network and Dial-up Connections.
    NOTE: For Windows Server 2003, click Start, point to Control Panel, and then point to Network Connections.
  2. Right-click the appropriate dial-up networking connection, and then click Properties.
  3. Click the Networking tab, and then click Settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected).
  5. Click OK, and then click OK.
  6. Double-click the connection, and then click Dial.
    • If this procedure resolves the issue and you can establish a dial-up connection, you do not have to follow the remaining steps in this article.
    • If this does not resolve the issue and you cannot establish a dial-up connection, go to step 7 to continue to troubleshoot this issue.
  7. Right-click the connection, and then click Properties.
  8. Click the Security tab.
  9. Under Security options, click Allow unsecured password in the Validate my identity as follows box, and then click OK.
  10. Double-click the connection, and then click Dial to verify that you can establish a dial-up connection.
May 11, 2011 | Computers & Internet
What is the network secuirty key for my belkin 54g wireless router? Help!
1. network security is setup by the user
You either have it or you will need to go through the set and establish a new network security key again via the CD that came with the router device.
Apr 15, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My sierra modem won't connect. it shows - Error 734: the PPP Link Control Protocol was terminated
hi there.
    -or-
To resolve this issue kindly follow the below steps and do not skip any of them:
Dec 19, 2010 | AT&T Computers & Internet
My psp won't connect to the internet. it says, a commection error has occured. a connection to the access point could not be established. check the security settings for the network and try again.
First of all check if your wireless router requires (WEP KEY) to establish a connection then you will have to put same (WEP KEY) in PSP WLAN security setting and if your wireless router is set without (WEP KEY) then in PSP WLAN security setting it should be set to None. kindly refer to the following image.3782ff8.png
Oct 20, 2010 | Sony PlayStation Portable (PSP) Console
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
When i dialled up inter net then error 734 was coming and say subscribe packet data first now ???
  1. Click start, settings and the network and dial up connections
  2. Right-click the appropriate dial-up networking connection, and then click properties
  3. Click networking Tab then settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected, it must be uncheck).
  5. Click ok, then ok.
  7. Right-click the dial up connection, and then click properties.
  8. Click security tab.
  9. Under security options, click allow unsecured password in the validate my identity as follows box, then click ok.
  10. Double-click the connection, and then click dial to verify that you can establish a dial-up connection.
Jul 23, 2010 | Computers & Internet
When i connect to internet there is an error code 734
Feb 27, 2010 | Nokia E51 Smartphone
SYN packet for established connection
Check the "TCP end timeout" setting. You can find in Policy -> Global
Properties -> Stateful Inspestion. FW-1 will take a connection out of
its established connections table after two FIN packets (one from each
party) or a RST packet + the time defined in this setting.
Have a great day,
Bhautesh
Feb 18, 2010 | Nokia IP 440 Firewall
Psp internet connection
common is there anything you can do to fix it
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
Cisco WLS G BROADBAND RTR-54MB PER SEC W/ 4PT SWCH Router Logo
18 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
