Question about Refrigerators
Both fridge and freezer have stopped cooling and in fact the ice maker began giving off immense heat. The compresser is very hot as well and have had not issues with the fridge until sometime today.
  • 909 Answers
I suggest you switch the fridge off immediately and defrost totaly for 12 hours. Very possibly the door has somehow been opened slightly by mistake and moisture has found its way onto the evaporator plate. This will either stop the evap fan motor from running and or totally block the evaporator which will inturn give you the results that you are experiencing now. After total defrost, switch on again and listen for the fan motor which comes on once the door is closed. Normally all should be good.
Posted on Aug 29, 2010
My frig freezes top and also spoils coleslaw freezes water beer tried everything
First, call your fridge vendor for service.
*** the following is for information only. ***
* You need a full defrosting as there is ice in your cooling coils.
* Move food items to another refrigerator.
* Do a complete DEFROST of the box. (unplug it.) Expect it to take 4 or more hours. You must wait till all water stops dripping out of the fridge. Keep checking the lower defrost drip tray at bottom of fridge. Dump out water from tray as needed. DO NOT you a hair drier or any other heat source! The heat will warp the plastic. Use a small fan to gently blow into the freezer section.
* DO NOT use an ice pick or sharp object to remove ice! Just let everything melt. (The problem of ice is inside the coils)
* Plug in Fridge but don't put any food in. Set dial temperature to the Mid range setting. Set to freezer venting to normal. Set the refrigerator to mid range. Let it cool down to 0 - 10 degrees and start making ice (in ice maker) If it does not cool down to at least 10 degrees F then call for service. Suspect bad thermostat, Blocked condenser coils, Bad pump, etc. Qualified service tech required to repair.
* Cooling okay? Reload food but don't stuff it in. Leave space between the walls to allow cold air to flow around foods. It will take a day or so to cool down food properly. Note: I may take longer if this fridge is near a heat source like a Hot water heater, Oven, Range, Steam radiator, etc.
* If your still icing up in 2-3 weeks. Then check if the coils are icing up. Defrost is not working. This needs to be checked by a tech. Have him perform annual maintenance.
* Check door seals. Kids leaving the door open? High humidity? * Note how everyone uses the fridge; are they putting hot food in it? Open hot steaming food adds heat and humidity to fridge. Hot food with thaw out other frozen food and build up frost.
* Final, Have a Tech check your fridge. Have them perform maintenance and replace worn items as needed.
Aloha, ukeboy57
Mar 21, 2018 | Refrigerators
LG FX28977ST the freezer only gets down to 32 degrees and the refrigerator only gets down to 43 degrees. It seemed to work fine until two days ago when it quit making ice and the ice cream got soft.
First, I'm not a LG Technician. Call your LG vendor for service.
Aloha, ukeboy57
Mar 12, 2018 | LG Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
These will help.
Thanks,.
We had to move our Kenmore 18 fridge to install new flooring. When we hooked it back up, we noticed the 3 sides of fridge (freezer sides & top) were hot to the touch. We have a Kenmore18 with an...
its understandable that you fear the unit catching fire but in that the fridge must get hot in order to work. as the heat creates the cold but! in this case i would say your cooling fan placed at the rear next to the compressor has either stopped working or is in need of its blades being cleaned much like a cooling fan in the home when the blades get covered in silt it stops pushing as much cool air around its blades as per clean ones. so make sure the cooling fan turning on and give the fridge a good clean on the outside around the motor area. most importantly dont worry about fire the unit has many built in safety devices before that happens.
best of luck to you
please take the time to rank this repair
merry christmas
Dec 07, 2010 | Kenmore Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Strip between freezer & fridge
light falshing is normal, the strip between being hot is not though, remove the kickplate from under refrig and vaccuum the coils, pull unit out and clean behind, while there make sure that the fan adjacent to compressor is running(when compreessor is on). clogged condensor =hot mullion stip. not a major problem
Mar 02, 2008 | Kenmore 51252 / 51254 / 51259
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
