Question about Casio Exilim EXZ75 Digital Camera
I put the battery in the charger to charge . All that happens is the red light will flash, and the battery wont charge. Do i need a new charger or battery. How much will either one of these cost or will it be better to get a new camera
  • 3,083 Answers
The first thing to do in this case, is to measure your battery charger's voltage output with a voltmeter. Then measure your battery. Clean the battery contacts on the charger, battery, and inside the camera with a qtip and isopropyl alcohol, or pencil eraser. You can get a battery and charger on Ebay, if you decide to. Here is an excellent blog about this problem, and things to try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If you find you have a bad battery, or charger, it might be worth buying, however, you can get a pretty good new camera fairly affordable these days, it's your call.
Good luck, hope this helps, please rate this if it helped, and thanks for using FixYa.
Posted on Aug 29, 2010
My JBL CHARE wont charge it will only flash a red light
I assume you mean a JBL Charge. As for that specific model I am unfamiliar, however if when you try to charge electronics they will only flash a red light that's usually a battery or charger error signal. Most likely either a battery in the battery pack has gone bad, a contact has come loose or your charger has broken. Did you happen to drop it shortly before this error occurred? Also was the battery completely dead right before this happened? Sometimes I have noticed wireless devices will refuse to charge a battery if it is completely drained.
Dec 02, 2014 | JBL Audio Players & Recorders
Put battery in charger and red light just flashes. put battery in camera and nothing happens
This is usually because the battery is faulty and needs to be replaced. Just to be sure, turn off the charger and then back on again. Put the battery back on charge to see if the error is repeated. If so you will need to obtain a replacement battery. Unfortunately, this does happen with a fair number of rechargeable NiMh and Lion batteries and many are no where near there expected lifecycle of 1000 recahrges.
Oct 13, 2009 | Casio Exilim EX-Z77 Digital Camera
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
May 29, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mar 26, 2009 | Casio Exilim EX-Z77 Digital Camera
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Aug 24, 2007 | Casio Exilim EX-S500 Digital Camera
When i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Jun 11, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
14 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
