How to fix the start button on kenmore quiet guard dishwasher. It sometimes does not work unless pushed very hard
  • angelfish172 Sep 18, 2008
    start button getting very hard to push on the panel the rest are easy
    Genius:
  • 1,073 Answers
Replace the touch pad
Posted on May 07, 2008
How do I reset my panel for my kenmore precision dishwasher with quiet guard
Just hold the Start button for 3 seconds, and it should drain and shut down.
Sep 16, 2014 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard Dishwasher only starts when pressing start repeatidly
No personal experience with this machine, but two things come immediately to mind:
1. If the door latch is not quite closed then the machine still thinks it is open and thus will not start. Try gently pushing on the door as you push the start button. If no joy, then check to make sure that the latch mechanism (what can be seen of it - usually very little!) has no food deposits on it.
2. The start button contacts may be corroded. Try pushing the start button more firmly - and wiggle it at the same time.
Jul 16, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher 665.17979301 - Reset Sequence?
Try pushing the Sani-Rinse and Air Dry buttons back and forth a number of times.
Apr 20, 2007 | Kenmore 24 in. 15142 Built-in Dishwasher
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
