Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
How can i format pan-drive with dos - Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
    Brigadier General:
  • 10,406 Answers
Determine which drive-letter (not A: and not C: and not D:) that Windows has assigned to the pen-drive.
Then, enter: FORMAT x: /Q
where "x" is the drive-letter.
Posted on Aug 29, 2010
I have a IOMEGA 1TB hard drive, and I formatted It and it gives me only 92.7MB free out of 92.8 MB and not the full 1TB and I'm using on my PC windows 8 pro and It won't back up all my files what do I do?
I would connect drive and from dos prompt run diskpart. Make sure you have extended dos partition that has the entire drive space. You can type at the dos prompt: diskpart ? for help. Once you have partitioned the whole drive format it with NTFS.
Oct 25, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
When Formatting the C: in DOS (Format C:) what does it mean when you get the following error: Format cannot run because the volume is in use by another process. Format may run if this volume is...
If the computer is running you will not be able to format the C: drive. You will need to restart the computer with a boot disk, boot to a DOS screen, and format C: drive from there. Just remember this will wipe everything on C:, including your operating system, so you will need your windows reinstall disks handy.
Jan 10, 2011 | HEWLETT-PACKARD HP G71-445US Notebook
How to format my c drive help by dos
If you are running DOS(Command prompt) in Windows, your windows Operating System is installed in C drive and is Up and running then it is impossible to format the C drive because the whole thing is running in C drive and windows won't allow you to do so.
But if you are using a separate DOS O.S. and want to format C drive and If you want to format any other drive than c drive when your system is up and running then you can use the FORMAT command followed by the drive letter that you want to format.
here is an Examle to write in DOS..
Format C: /q
you can replace the C letter by any drive that you want to format. The /q Option is use to perform Quick Format. Here is a list of mostly used Option
Formats a disk for use with Windows.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/C] [/X]
"volume" Specifies the drive letter "/FS:filesystem" Specifies the type of the file system (FAT, FAT32, exFAT, NTFS, or UDF). "/V:label" Specifies the volume label. "/Q" Performs a quick format. "/C" volume will be compresse by default. "/X" Forces the volume to dismount first.
Hope this will help for sure.....cheers:)
Sep 28, 2010 | Computers & Internet
How to format samsung nc10 notebook
You will and external CD-ROM or DVD ROM in order to format the Netbook.You can used MS-DOS to format the Hard drive.
Yopu can download the bootable MS-DOS using the link below
http://www.ulink.net/crossroads/computers/sli/boot622.exe
or you can use any Windows XP Bootable CD to format the hard drive too.
Feb 28, 2010 | Samsung NC10-14GW Notebook
Giga ONe hard drive reformat
You can format your giga one hard drive in MS-Dos mode.
1. Go to Start--> Run
2. type CMD to enter the DOS
3. select the giga one drive path (i.e. if it shows as E drive then simply write E: in DOS and hit enter.
4. type format
thats all that you have to do to format the giga one drive.
Jul 28, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Not able to format 32gb kingston usb pen drive
go to start>
run>
type cmd
ms- dos window appears
if your drive is g: then type following codes on dos
format g:
y
either your drive is f: then
type
format f:
y
donot forget to rate if it becomes formatted
by Nischal nisc
if you are using vista then
go to my computer right click on my computer
manage>
then you can format by entering device manager
Mar 29, 2009 | Electronics - Others
I have 8GB pendrive of transcend. when ever i want to format it, screen shows that window is unable to format it. i have window XP SP2
format it by dos
start>
all programs>
run>
type cmd
format it by
format g:(you type in ms -dos)
if you drive is f then
type
format f:
Mar 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't make format, partions or install windows.
Hi shlmughni,
If you're trying to format this drive, and you have nothing on it you want, then I would suggest that you use a windows 98 boot disk HERE. And first thing you need to do is load dos by putting the floppy disk in your drive A: after you create it from that site of course. Then allow dos to boot up. I'd opt for the allow cd rom option when it asks. After you get a dos prompt A: type in fdisk. Go to the display partions section and see what your drive is partioned as? Once you find that out, I'd delete the partion from the main menu choice delete partion. After that create a new partion from the main menu. Creating a new Dos partion will allow you to choose the size of the partion you want, then after that it will create your new Dos partion. When that's done, exit fdisk, and go to the A: prompt and type in format c: This will format the drive all over again, and give you a clean fresh starting point in which you install your OS.
Good Luck
Mark
Jan 03, 2009 | Maxtor Hard Drive
Electronics - Others Logo
57 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
