Question about Galaxy Radios DX- 88HL Base CB Radio
I have a Galaxy DX88HL, newer style I think. I want to know if anyone makes a white frequency, and channel display? If so, where can I find one, and how hard are they to install? The reason I am asking, I have it installed in a Black convertable, with white interior. I already have the white LED in the signal meter. Thanks in advance for your help......
  • 64 Answers
I have seen Blue and Yellow but not white as of yet.
Posted on Sep 13, 2010
Dx44v frequency chart
first , Is this a new radio ? If it is then send it back to Galaxy .Its under warrenty for 3 yrs.Second if its not then make sure you are on the cb band . it should automatically display the frequencies.
Nov 01, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxy 88hl
always check your swr's.. it should be fine with those settings.
90% amps 1 to 5watts input is fine and then the modulation wattage of yours is good. most can take 50w RMS.
use short coax jumpers.. make sure the radio doesn't have the modulation limiter cut. and it is on frequency. and it should be good. maybe try putting little bit of wd40 on the microphone switch to see if thats the crunching sound..??
also make sure you have enough amperage.. and a good heavy gauge power wire to the amp..
if you have any more details let everyone know.. may help narrow down a problem.
May 03, 2013 | Radio Communications
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Nov 03, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Changing colors on a Galaxy 88 or DX-88HL or DX88
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Oct 20, 2011 | Galaxy Radios DX- 88HL Base CB Radio
On my radio I need the settings for the knobs because other people can hear me but I only get static and cannot hear them. Thanks
Band should be E Band high/low button on high 10 khz off AM selected
To check that you have done this correctly frequency counter will read 27.185 plus or minus 5 khz. This is of course proved you have a radio that is converted for 11 meter cb frequencies.
http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm Frequency Conversion is the channel expansion mod/conversion
Sep 16, 2011 | Galaxy Radios DX- 88HL Base CB Radio
What are the buts & nubs go to make the cb work which ones trun or push ?
Assuming you're talking about the Galaxy DX88HL, and assuming the mad has been done to reach the 11 meter band, you press the band button in, that put's you to the E-H banks, select the E/A bank which is high bank E. with the frequency counter on, it should read 26.965 for channel 1. If it reads 26.975, then your +10KHz switch is on, turn it off. you'll then be properly set for 26.965 (ch.1) - 27.405 (ch.40). You also have 5 "hidden" frequencies, these are at ch. 3, 7, 11, 15 and 19. To get to the "hidden" frequencies, go to any of the channels listed and turn on your 10KHz switch. Those frequencies are not attainable on radios that do not have a +10KHz switch or a clarifier capable of sliding that far over. To do repairs and for a full list of schematics, diagrams and so forth, I suggest this site, it has the most coverage of the Galaxy DX88HL as well as other galaxies that I've been able to find. http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm .
May 25, 2011 | Galaxy Radios DX- 88HL Base CB Radio
I need a instuction manual and freq. cheat sheet for my galaxy dx88hl.thanks Rod
To use this radio on the CB band, you set the 10 Khz switch to OFF, and then turn the band switch to A/E.
Here is a Frequency Chart.
Here is the manual.
When the 10 Khz switch is on OFF, the band switch is E,F,G,H. When the 10 Khz switch is in the ON position, then the band switch is A,B,C,D.
So when you are on band E, which is when the 10 Khz is OFF, and the band switch is in the first position, it is on the E band.
I would get your self a Frequency counter. It makes using a radio like that much easier.
Hope this helps!
Oct 11, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy dx88hl locked on 25.175mhz low band only.hi channels & am ok
Hi and welcome to FixYa,
Initially, possible faults with the BAND switch, BAND HI LO switch, or any of the diodes in the matrix.
Offhand, perhaps the schematic diagram of the Band Board would help.
Good luck and thank you for asking FixYa.
Dec 17, 2009 | Radio Communications
Galaxy Radios DX- 88HL Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
