Question about Onkyo DX-C390 6-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
WHEN I PUT THE DISC HOLDER IN GOES FROM 1 TO 2....ETC ALL THE WAY DOWN THE LINE BUT WONT PLAY ANY DISC ....ONCE IT GOES THROUGH THE 6 DISC IT IS STUCK CANNOT DO ANYTHING ELSE UNTIL I EJECT
  • 1 more comment
  • dduct May 30, 2008
    I have a similar problem with an Onkyo DX-M505. The unit cycles through all of the cartridges, picking none to play,then returns to the top and stops. I've opened the unit and see No light emitting from the pick up or eye (laser?).
    Any help??
    Thanks
    Dave
  • fk56303 Jan 02, 2009
    I am having the same problem. The unit opens and the cd tray circulates fine, but it won't read any cd's or play them.
  • fk56303 May 11, 2010
    How is the unit opened? Just loosen the screws or are there any special tools needed to open it?
    New Friend:
My onkyo 6 disc changer was doing the same thing was doing the same thing. i opened it up and noticed the cds weren't quite stopping at the right spot. so i loosened the screw right in the middle of the disc tray. now operates perfectly now. i think maybe with age, the belt tension got a little lighter ant loosening the screw compensated for it.
Posted on Mar 24, 2013
  • 4,234 Answers
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
Posted on May 07, 2008
What is the most likely cause of a "NO DISK" error with the Onkyo DX-C390 6-Disk changer? Would it be the laser pickup assembly?
Could be dirty laser lens, dying laser, faulty component,
Due to the complexity of multi-disk changers, it may be best to have the device looked at.
You can try running a cleaning disk through it first, but from your post, it sounds like this unit may have multiple problems and need tested by a physical person.
Nov 24, 2014 | Onkyo DX-C390 6-Disc CD Changer
ONKYO CD DX-C390 6 CD CHANGER NOT READING
No laser, means no laser. Typical symptom of laser failure. Most CD players can have the laser replaced fairly easily and cheaply.
Contact your local technician, and he should be able to replace it quickly.
Oct 30, 2014 | Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
It doesn't close or open without assistance and now the player doesn't turn to find the disc to play. It played 2 days ago, but after changing the discs and pushing the tray to close, the turntable part...
almost all the gears in there are plastic and the motors are replaceable. it will wear out after a while. if it is the motor, you can get a replacement from mcm electronics on line. if it's the gears, you'll need to replace the whole assembly.
Dec 14, 2009 | Onkyo DX-C390 6-Disc CD Changer
I can't turn on the unit.
no on/off switch on this model; use the remote or load it and press play AFTER you plug it in............
Jun 06, 2009 | Onkyo DX-C390 6-Disc CD Changer
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
Cd stuck in
take the cover off and take the CD out
Oct 06, 2006 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-C390 6-Disc CD Changer Logo
961 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
