Question about iiyama ProLite E386-B Monitor
Necesito ayuda, he perdido el transformador que viene con el monitor y tengo la pantalla nueva, no lo encuentro¿dónde lo compro? El monitor es iiyama prolite E386 Model : PLE386-BOX. Amperes 3.04 Volts 12 v. Wat 36 w. Me urge. Gracias
SOURCE: colour changing
thanks worked perfect
Posted on Aug 31, 2008
Geekman
  • 32281 Answers
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 28, 2009
  • 732 Answers
SOURCE: I would like to know how to remove the cover
iiyama573, Visit YOUTUBE and search and view the longer video clips of "LCD monitor disassembly" and "LCD repair" to see how a typical cover is removed. 12fixlouie on fixya
Posted on Oct 27, 2009
Geekman
  • 32281 Answers
SOURCE: Where on earth could I find the data for an Iiyama
This PDF file provides the Diagnostic info for the E435
lease click on this link to download this PDF file :-
http://www.koyoele.co.jp/english/support/pdf/DL205_M1.pdf
Posted on Jun 06, 2010
SOURCE: iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Posted on Apr 25, 2011
Desconecte una caja doble de dish y ahora uno de los televisores no funciona
Hola Jorge, disculpe la demora en responderle, quizas en este momento ya no necesite la respuesta para este problema pero me gustaria proveerle los detalles de todas maneras por si en futuro necesita ayuda esto le pueda ayudar. Este problema lo puede ocasionar distintas razones. El primer paso a tomar es: Por favor verifique que luces estan prendidas enfrente de su receptor. Bajo donde dice MODE la luz debe de estar en DUAL (2 cajitas) si esta en SINGLE, abra a puerta enfrente del receptor, oprima el boton que dice 'Mode' para poner el receptor en DUAL. Si este no es el proble may esto no lo arregla necesito que en el cuarto del televisor numero 2 (donde NO esta el receptor) usando el control que vino con la TV cuando la compro que ponga la Tv en el canal 60 si tiene una imagen necesito que agarre su control de DISH y en el control oprima el boton de SAT (el cual se encuentra en la parte de arriba a mano izquierda) una vez haga esto, trate cambiar canales. Si esto no funciona, otra vez con el control original de la Tv trate de poner la Tv en el canal 73. Si le sale una imagen, agarre el contriol de DISH, oprima SAT y trate de cambiar canales.
Si lo recien explicado no le funciona, valla a la TV 1 otra vez. Con el control 1 en mano Oprima Menu y una vez tenga el "Menu Principal" en la pantalla Oprima el numero 6, espero dos segundos y oprima el numero 1, espero otra vez dos segundos y oprima el numero 5. Este proceso lo lleva a una pantalla llamada 'Modulator Set Up' En esta pantalla donde dice 'TV 2 OUT' bajo 'Channel' que numero de canal tiene? 73 o 60? Basado en el numero valla al cuarto de TV 2 y usando el control que le pertenece a la Marca de TV (no el control de DISH) ponga la Tv en ese canal. Esto tambien debe de resolver el problema. Si necesita asistencia con su servicio de DISH sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Sep 22, 2013 | DISH Network 322 DTV Receiver
No tengo el OCR para lexmark X1290
La Lexmark El software de OCR análisis sólo puede ser instalado utilizando el disco de instalación de Lexmark que viene con su impresora. Si usted no tiene el disco o la has perdido, tratar de comunicarse con el Centro de Soporte Técnico de Lexmarkpara obtener ayuda.
Nota: Esto se traduce utilizando translate.google.com.
Aug 31, 2011 | Lexmark X1290 All-In-One InkJet Printer
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Mar 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Da?±a el transistor horizontal
Hola,
El transistor de salida horizontal es un 2SC5331 (Q303). Por favor también compruebe el transformador Flyback (FEA661).
Estará bien comprobar también Q103 (IRF740) que es el regulador de recorrido HV. En algunos casos, D123 defectuoso en el recorrido G1 puede causar el HOT a corto.
Un diagrama esquemático / manual de servicio está disponible aquí.
Tengo que hacer el uso de trnaslator en línea para contestar a su problema.
Buena suerte y saludos cordiales.
Jan 04, 2008 | ViewSonic G790 19" CRT Monitor
iiyama ProLite E386-B Monitor Logo
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
