Question about HP W2338H Monitor
Monitor comes on for a split second and shows display and then won't come on after that
  • 11,361 Answers
It can have bad caps in the power supply or failed backlight inverter circuits. Please see more here:
http://www.badcaps.net/forum/showthread.php?t=10633
and here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 29, 2010
Led will not show.comes on for a second then blank
James, sounds like a power supply issue.links below to shed some light on your issue.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
How to Fix LCD Monitor Power Problem
MOST COMMON REPAIR FOR LCD NO POWER
Fix Malfunctioning LCD Power Supply
How To Test Computer Monitor That Won Display Or Is Not Working
Feb 15, 2016 | Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
When I update my display driver from standard VGA
hi, you can first boot it in safe mode,, then go the display settings,, from control panel,, then change the things,, where you can find,, double display.. and single
Sep 27, 2009 | Toshiba Equium 7100S PC Desktop
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
HP W2338H Monitor Logo
380 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
