Question about Panasonic Lumix DMC-TZ15 Digital Camera
I HAVE A PANASONIC DIGITAL CAMERA MODEL DMC-TZ15 WHEN SWITCHING ON CAMERA OPENS LENS BUT DOES NOT ZOOM IN AND STAYS LOCKED IN THE BLUR POSITION A MESSAGE APPEARS SAYING :PLEASE TURN CAMERA OFF AND THEN ON AGAIN.I TRIED SEVERAL TIMES AND THE SAME MESSAGE APPEARS CAN YOU HELP ?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 15, 2010 | Panasonic Lumix DMC-TZ15 Digital Camera
I have the Panasonic dmc-tz1 it keeps saying to turn camera off then back on. I do this and still cannot take pictures or use camera!!! HELP!
You surelly drop down the camera or you have some sand inside the zoom lenses movement. You need to open the camera, opens the zoom lenns the clean the gear or replace the broken gear inside lenses
Nov 08, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Feb 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Zoom lever sticks
Hi, the only reason the zoom lever sticks is dirt. Either dust or some sort of liquid may have spilled on the camera. If you wipe it off, it does not help as the liquid gets into the zoom lever mechanism.It will have to strippd and cleaned.
Jul 13, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix DMC FX8 lens cap opens intermitently,some images shoot rotated 180 degrees
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then.
Feb 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Panasonic Lumix DMC-TZ15 Digital Camera Logo
118 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
