Question about Acer PD100 Multimedia Projector
Acer PD100 overheating
My acer PD100 is overheating. It will stay on for about 20 minutes when started from a cold state (less when starting warm). It gives the overheating warning in both standard and eco modes and then shuts down.
I used an electronics vacuum to clean out all the vents and it seemed to stay on longer for a day or two. I've tried a new lamp with same results.
Any ideas? Should I try to replace the cooling fan?
  • DaveMcCall May 08, 2008
    The fan is running, though it doesn't seem to be varying in speed at all. It is running at a low RPM, so I'm guessing that a fan replacement might do it.
Solved ! I had the same problem. After connection to notebook and after attempting to correct colors. Overheating after two miutes and shut down. Reassembling aned cleaning was not helpfull. All seemd OK. Resetting the factory default was not helpfull too. But, I tried something, what ist restricted. After aprox one or two minutes, no more of projector work, I switched out the power not correctlly according the documentation, but the main cable from the wall outlet. I was little bit angry and this is what why I forgot if I tried this procedure ones or more time. But, that was hepfull, and projector now runs correctly. I supposed, that my experiment made "reset" of something. I would like if that solution wil be helpfull for you. Kamil, Prag.
Posted on Mar 29, 2011
  • starec May 30, 2011
    Thank you Kamil, it was helpful. Dusan, Bratislava
I found that by resetting the factory defaults the problem goes away. I have experienced this issue a few times after attempting to correct colors.
this projector does not have the best picture or color quality.
Posted on Feb 20, 2009
I just spoke to a repair agent for Acer projectors about this problem. It was a very common problem with this model (PD100) and Acer never really got to the bottom of it. There is a 50/50 chance that upgrading the firmware will resolve the overheating issue. The rest of the time a replacement mainboard is required to solve it. Unfortunately this firmware is usually only available to Acer channel members. If you do have it you'll need to upload it via a usb dongle of some kind. If anyone manages to locate the latest firmware please let us know where to find it. Thanks.
Posted on Oct 28, 2009
I have an acer PD100, and i am having the same problem. But what I discovered is that the projector only overheats when you connect a video source to it. It will run for an hour, but as soon as i connect a source, within less then 2min the unit will display the overheating warning and then shutdown. The crazy thing is this is my second PD100 to do this. the first one i had did this after owning it for only about 3 months. Acer replaced it finally after sending it in to be repaired 3 times. Now the new has started doing the same thing about 4 months after i got it. (Has less the 150 hours on it) This really disapoints me in Acer, because I have been using Acer Aspire products for years. If anyone has any idea how to repair please post a comment. It is really disapointing paying $860.00 for a projector that doesn't work.
Thankyou,
Matt
*Next time i'll go with View Sonic"
Posted on Sep 19, 2008
  • 563 Answers
Hi DaveMcCall
Yes this could either be a fan or a sensor that is faulty and will need replacement.
Both are very cheap and easy to replace.
Try checking first of all if all the fans are working ok.
Posted on May 08, 2008
Acer dlp power shut off after a few minutes on
That's typically caused by the thermal protector. If the fan is running normally and there filter (if there is one) is clean, then the thermal sensor has probably gone bad. It will need to be sent to a repair center.
Jan 24, 2014 | Acer PD100 DLP Projector
1989 olds 88 hard to start at 32 degrees and below
be looking at vacuum leaks and stuck valves when cold..
Dec 30, 2013 | 1989 Oldsmobile Delta 88
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20...
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Oct 21, 2013 | Acer Aspire One PC Notebook
Acer Extensa 4420 overheating
The laptop must be dismantled to access the motherboard, buy a can of compressed air attach straw. Now remove fan and the heatsink, blow out all open ports and fins on the heatsink and fan, next! remove thermal grease from the processor and heatsink with rubbing alcohol and a paper towel, now! apply fresh thermal grease to the processor and heatsink, "small thin layer evenly spread" now assemble, "solves most heat related issues"
Apr 19, 2012 | Acer Extensa 5630-6806 Notebook
Acer Multimedia Projector PD100 DLP overheating problem
blow the dust out of it with canned air, make sure the fans are all spinning. this should remove the causes of overheating. if it still says that it is overheating, replace the thermal sensor (usually near the lamp or the lamp fan).
Jan 12, 2010 | Acer PD100 Multimedia Projector
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
ACER PD100D Overheating
I found that by using the menu to reset to factory defaults fixed the issue. It appears to be a combination of settings that causes the issue. I have created this situation a few times while trying to get more accurate colors from the projector.
Jan 05, 2009 | Acer PD100 Multimedia Projector
My cd cracked for the projector acer pd100 series
Hi there
Very simple - go back to the dealer you bought this from and tell them the CD was damaged when you opened the box. They will give you a new one on the spot.
Mar 20, 2008 | Acer PD100 Multimedia Projector
Acer PD100 Multimedia Projector Logo
1,086 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
