Question about Kitchen Ranges
Frigidaire range i have a frigidaire range. we had a power failure and now it flashes F30.i can't get my oven to work and i can't set the clock
When we push the BAKE button F30 flashes. The clock will not reset. Help! Is there a reset button? I really do not want to pay a service man to push a button.
Posted on May 22, 2008
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 08, 2008
My frigidaire professional series showing error code F 30 and oven not turning on
Good Morning Friend,
I understand you are receiving an F30 code on your Frigidaire range, model# PLEF398AC, and it will not turn on. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Help me with my Frigidaire Es510 Control Self cleaning,Oven with deep well style cooktop It has the time flashing but will not respond and it also has PF on it
The CLOCK pad is used to set the clock. The clock may beset for 12 or 24 hour time of day operation. The clock has beenpreset at the factory for the 12 hour operation. When the range isfirst plugged in, or when the power supply to the range has beeninterrupted, the timer in the display will flash with power failure "PF"
Instructions:
To set the clock (example below for 1:30):1. Press the round "CLOCK" button. "CLO" will appear in the display (Fig. 2).2. Press the round "1" "3" "0" pads to set the time of day to 1:30 (Fig. 3)."CLO" will appear in the display. Press the round "Start" button. "CLO" willdisappear and the clock will start (Fig. 4).
Oct 10, 2011 | Kitchen Ranges
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire Professional Series Range - F30 ERR
door will not unlock after cleaning
Jun 11, 2009 | Kitchen Ranges
Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
337 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
