Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi vs5043 convergence
Hello premte, I have a red convergence issue with my set. The shop quoted me $380 to replace all three, and that was the only way they would fix it. I understand that is what it is, but the set is not worth the $$ to me to fix. In your opinion how difficult is it to repair this with plenty of previous soldering experience and industrial equipment? While I am in, any resistors/capacitors you would recommend replacing? Thanks, Jim
  • Mitsubishi Master
  • 8,617 Answers
Your chassis is a VZ3 that chassis should use two STK 391-020 ICs Its an easy repair Mitsubishi usually will not blow resistors when the ICs go out. You can get the replacement ICs at the following link and they provide free step by step instructions with pictures so if you have even basic soldering skills this isa job you can do in about 30 minutes . Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 18, 2008
Can't converge red on the edges
Depending on the actual model number the set uses either one or two convergence chips and both would now have to be replaced.
Set as you know has convergence mode in customer menu and another in one of three hidden menus.
Jun 17, 2012 | Mitsubishi WD-65000 65" Rear Projection...
No sound,remote control
Please Note: The original remote (VS5043) is no longer available.
The remote below is the recommended substitute remote. Substitute remotes provide similar functionality to the original, although there may be minor differences.
VS5043 Original Remote Control VS5043 Substitute Remote Control zoomin.gif zoomin.gif vs5043.jpg vs5043_sub.jpg
link to buy
about speakers can you tell me that are you able to hear sound from speaker or not.or is it the remote that showing no speaker..if it is showed by only remote then no need to change speaker ,but if speaker are not working at all then you need to change speakers........
check through t.v volume button that sound comes or not.
please provide more information.
Jun 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
We can set the convergences great but after about 10 to 15 minutes ithe reds lines start moving a little again will not stay in position. It's a widescreen Mitsubishi rear projection tv ws-55857.
The problem - you're setting the convergence settings, but you're not saving them, you're
simply exiting the menu screen. Be sure to save your convergence setting for each
of the three colors. It sounds like you're setting RED last, and not saving its convergence setting,
whereas the GREEN & BLUE are holding their convergence settings, since you're saving them
correctly before proceeding on to RED....
Mar 15, 2011 | Mitsubishi WS-55857 55" Rear Projection...
It appears to be convergence issues. Red, green,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi VS5043 convergence will not align
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 22, 2009 | Mitsubishi VS-5043 50" Rear Projection...
PICTURE IS CURVED IN AND COLOR ARE SEPERATING INTO RED BLUE AND YELLOW
The part# STK392-570 amps need to be replaced.These are your convergence amps and are a common failure in projection sets..
Jan 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence problem - Mitsubishi 65
It sounds like your red gun might be close to going, we had the same problem our tv. The red was off and couldnt really be adjusted but the others were alright. We were told that the red gun was nearing the end of its life and it could cost upwards of $1000 to fix, so we just got a new tv. i would suggest having a tv tech come out and look just to make sure, but thats wut it sounds like.
Oct 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Mitsubishi vs 5071
Usually this problem is caused by bad convergence ic's. These hold the three colors in alignment. They are better to be replaced as a set of two or three chips and must be soldered/desoldered into the circuit board. Most shops charge 200.00-375.00 to do this repair. I hope this helps. Most bow problems are from convergence or pincushion circuits.
May 21, 2008 | Televison & Video
Televison & Video Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
