What is the spark voltage supposed to be on a honeywell s8600h ignition module
    Problem Solver:
  • 7 Answers
The amount of voltage, will not really help you. i mean, its on the thousands?? why would you want to know that?
Posted on May 08, 2008
Is there more than one modular on a 96 Blazer is one in the distributor
More then one modular ? Module ! Ignition module ? Which engine ? 2.2 L or 4.3 L
2.2 L has no dist.The electronic ignition (EI) system does not use the conventional distributor and coil.
4.3 L Enhanced Ignition System (Overview)
The ignition system initiates combustion by providing a spark to ignite the compressed air and fuel mixture at the correct time. In order to provide an improved engine performance, fuel economy, and control of exhaust emissions, the control module controls the distributor spark advance, or timing, with the ignition control (IC) system.
The ignition system uses a primary and secondary sub system in order to accomplish the timed spark distribution. The primary system consists of a low voltage trigger device which determines the base timing. This signal is modified by the ignition control driver (ICD) module. The signal travels to either or both the engine and transmission processor (control module) for base timing reference. Another signal is sent back to the ignition control driver (ICD) module, which has been adjusted by the control module (advanced or retarded) in order to trigger the coil, according to the requirements of the engine.
The secondary system consists of the ignition coil which has primary, or low voltage, windings and secondary, or high voltage, windings. The secondary side of the ignition coil generates a high voltage which high tension spark plug wires deliver to the spark plugs.
The control module controller now controls the ignition control (IC) and bypass functions.
In order to properly control the ignition and combustion timing, the control module needs to know the following things:
• The crankshaft position
• The engine speed or RPM
• The engine load -- manifold pressure or vacuum
• The atmospheric or barometric pressure
• The engine coolant temperature
• The camshaft position sensor
No module in the distributor
Dec 23, 2016 | 1996 Chevrolet Blazer
1985 chevy pick up replaced new pick up coil , distributer, plugs and wires also distributor moduler still no spark
do you have battery voltage present at the module when the ignition is supposed to be energized? Find a wiring diagram for this vehicle and engine, and then trace the battery voltage to the distributor and the ignition (distributor) module. Confirm the specified voltage is available at the right place when the ignition switch is in the RUN position, and not just the START position.
Sep 22, 2014 | Vehicle Parts & Accessories
Igniter on gas water heater only sparks once
First pull the ignitor wire off the ignition module...hold a screwdriver 1/8 to 1/4 inch away from the electrode pin on the module then turn the unit on to see if it sparks differently than what you described before you replace the ignitor.
Dec 19, 2013 | Honeywell Water Heaters
Keep replacing control
Check to see if anything on the low voltage circuit is stealing voltage ie gas valve...make sure you have the proper low voltage to the ignition module (check the transformer)
Nov 22, 2013 | Honeywell S8610U3009 Universal...
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
Fuel pressure is right on and has good spark at plugs. No voltage at injectors. Need to determine if it is ECM or ignition module. 1992 chevy cavilier
Check the input voltages to the ignition module. If they aren't what they're supposed to be, it's ECM or wiring fault. You need a wiring schematic to troubleshoot accurately on a problem like this.
Feb 17, 2011 | Cars & Trucks
No spark Ignition, no gas release from the valve.
I would replace the intermitant spark ignition module if it did not produce a spark from the spark terminal to ground if held 1/8" away. Honeywell makes a universal replacement. I think it is either a S8610U or S8900U.
Jan 31, 2010 | Heating & Cooling
Heater won't ignite when heater is turn on.
See if the spark will arc across the area where the pilot flame is. It should cross the flame. Adjust the spark if possible.
Nov 11, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
