Question about Sony Vaio FZ31M Notebook
My sonny vaio's display has garbage on it (it's like there's some pixels out of colors and the resolution problems) what may be the cause of it? BTW vgn-fz31m
I think i have the same problem with my Toshiba Satellite p100 i am having a heap of pixels with the wrong color on my screen and the thing is that the number of pixels position and color depends on the image on the screen any help
Posted on Sep 05, 2010
  • A1dan9 Sep 05, 2010
    I think i am haveing the same problem as you I am having problems with my Toshiba Satellite P100's display it only started happening when i installed windows 7 onto it the problem is that i am getting a heap of pixels in the wrong color and the number and position of the pixels depends on the image on the screen any help
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
I bought Toshiba satellite T135 last year but it has splash screen when I search the internet .How can I do to solve the problem?
When I read "twinkle", I have the picture of individual pixels flashing white in the middle of colored or dark areas. This would be a hardware problem (bad connections to those pixels), unless it occurs only when you are running certain programs. Usually if you have display connection problems, they will show up as an entire row or column of pixels stuck on one color, but intermittent single pixels are possible.
There are two types of flickering (flashing all over the display or an area of the display). In one, you will see irregular, mostly horizontal bands of slightly darker or brighter areas moving rapidly all over the display. This happens on some displays when the resolution is on certain settings other than the display's maximum ("native") resolution. For example, the native resolution of the T135-S1300 is 1366x768. (There are about half a dozen variants of the T135, so I only mention the one I checked for an example.)
The other type of flickering is caused by a problem with the backlight. Most of the older laptops have a fluorescent tube at the top and bottom of the screen. When these approach the end of life, they start to flicker, especially when the computer is first turned on, and often have pinkish tint. The T135-S1300 uses LED backlights, so that should not be a problem.
If you have a hardware problem, it would probably be one of the foregoing, and it would show up in all programs, or when you have nothing going except your Desktop picture. If the problem shows up only in the web browser, you may have some weird browser add-on or plug-in. What browser is it (Internet Explorer, Firefox, Chrome, Safari ...)?
Another possibility is a virus or other malware program. Open your anti-virus program, tell it to update its virus definitions, then run a full scan. Do the same with your spyware remover.
May 03, 2011 | Computers & Internet
What disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
HELLO, I INSTALL WINDOWS XP ON MY SONY VAIO VGC- V517G BUT THE SCREEN IS NOT FULL SCREEN ON THE MONITOR WHAT CAN I DO?
Right click the free area on your desktop, choose Properties, go to Settings tab and change the display resolution slider to the native resolution of your display, which is I beleive 1280x768 pixels.
Oct 29, 2009 | Sony VAIO VGC-V517G PC Desktop
Sony Vaio Laptop LCD pixulates
If you cannot change the resolution greater that 640X480 and the color quality greater than 16 bit, then the video driver appears to be faulty or not installed.
Check the video driver in Control Panel - System - Hardware - Device manager, the video driver.
Mar 20, 2009 | Sony VAIO PCG-F580 (SNPCGF580) PC Notebook
My screen resolution wont go above 640x480 pixels,16 colors
that probably the highest ur screen can go unless u update ur video card u can purchase some really good video cards at Best Buy or Wal mart Looking to help u Shaun
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Display Problem
First things is to see if the problem is
  1. memory related(these all in one units have a problem that way.)
  2. Run everesthome and update chipset<NORTHBRIDGE>Google the northbridge for updates.
  3. nVidia GeForce FX Go5700 problem.Make sure all updates for graphic drivers have been installed, then attach an external monitor, the unit should support svga/dvi/s-video. Your graphics card has 128MB dedicated so if the external display responds the same way as internal monitor it's the video card or chipset.
May 07, 2008 | Sony VAIO VGC-V517G PC Desktop
Display gone pixelated
Every expert here has a Ask Me button under their user ID.
Suggest you ask, mewms_14904
Here is his link.
http://www.fixya.com/users/mewms_14904
Diplay setting changes made but the color or resolution is still bad.
I have a similar problem with this monitor, i always after connecting having to go to the "screen Position and Size" setting in my ATI FireGL. and shift the screen 1 pixel, and the color and resolution turn ok, it is manual step, but better than no fix
Jan 23, 2008 | ViewSonic Televison & Video
Sony Vaio FZ31M Notebook Logo
279 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
