Question about Garden
Handles will not stay extended when in use even when terminal end of extended handle is locked
  • 1 more comment
  • johnhm29 Aug 30, 2010
    Make is Fiskars but no Model no,Handles are 39 cms long which extend to 79cms.
    On the end of the handle is an Open or Close portion which is turned to the Close
    position to KEEP it in the extended position. However this state is not maintained
    as the handle tends to slip back to the unextended state! The unit has silver handles
    with black grips and orange turn buckles at the end with Open Close positions and
    the appropriate arrow Any help? Thanks John
  • johnhm29 Aug 31, 2010
    The second line of your reply is missing, so details are hard to understand.
  • johnhm29 Sep 02, 2010
    Thank you for your help. Will try and advise. John
  • 11,896 Answers
Does it tighten well or is the bolts/nut stripped?
If it does not get tight it may loosen through vibrations. If it does not get loose, you can always remote the terminal, cover the bar with a 2 or 3 time electrical tap, then put the bar back on and they should stay in place well. The terminals can get slightly seperated where they hold fairly tight but can slip eventually. If the bolt is long enough through the handle and terminal, you could try a lock washer or loctite that will hold it. The tape on the handle bars will help them from slipping out of position.
Posted on Aug 31, 2010
  • 944 Answers
There is a locking pins which is attached terminal.Once you close the portion these locking pins will get locked the
extended cord.The locking pins is the problem.You can get it in the service center Lock lever Hinge cost is 6$.
If you don't have great hands on in it.Take it to the service centre.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
http://www.fixya.com/PostAnswer.aspx?thid=5783921
Posted on Aug 30, 2010
  • 2,926 Answers
Is there a make and model number for this machine? I'm not sure what handles we are speaking of. Thanks.
Posted on Aug 29, 2010
  • GetMeOttaHere Aug 30, 2010
    You'll need to replace the turn stops that lock the handle in place, or drill a hole and add a small bolt thru the handle to keep it in place. A model number would be great, but I was not able to find any parts without it. It seems this is an old unit also.
We opened the door, now door won't close. The closer rod is locked open
Turn the screw in the end of the shaft (on the door end) counterclockwise to release all the pressure.Once it closes or slams shut, use that screw to adjust the closing speed. Other problem could be the stay open lock (the metal piece that slides along the shaft) could be all the way out keeping the door from closing. If it is just push on the door a bit then slide the lock plate all the way back to the end of the shaft, and the door will close.
Dec 21, 2013 | Wright Products Tap-N-Go White Screen and...
HOW DO I FIX MY OFFICE BOSS CHAIR IT LEANS BACKWARDS AND WON'T STAY STRAIGHT
without sounding like a smart ***, have you checked the adjustors under the seat. Some handles are 3way handles and can do multiple adjustments. If you have adjusted all the knobs and handles, maybe it is leaking gas or in some case oil. Some of these chairs have an extra knob at the back of the seat along the column of the back rest, as to lock it in the desired position. Good luck.
Jun 01, 2012 | Furniture
JAguar door handles
You have something broke or not working inside the door. You have a huge problem. You will need to remove the door panel with it closed which is going to be hard to do. Once you can get into the inside of the door you will be able to inspect the linkage and figure what is the real problem inside. The door lock assembly will never work correctly till you find out if a clip broke and you can't know that till looking inside
Dec 02, 2017 | 2001 Jaguar XJ
Both door handles in the interior have broken off, it is amanual door lock. This is a 1999 Toyota Corolla
Get two new handles.
Unscrew the phillips screw located in the center of the handles. Slide the handle assembly backwards and out. Unclip the clip that holds on the metal lock-rod (needle nose pliers helps with that), and remove the lock rod. Fit the rod into the new handle's clip, and snap the clip into place on the new handle. Slide the front end into the door cavity, and then the back side. Reinsert the phillips screw. Very easy to do.
Thnaks for choosing FixYa for advice!
Mar 12, 2009 | 1999 Toyota Corolla
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Jane powertrack 360
There should be two black triangular attachments with little red handles that go on to the sides of the buggy. You use the grey handles at the end of the side arm of the buggy to pull the rear locking pins backwards and then slot the attachments on to the front pin with the red handle pointing forwards. Release the grey handle and it will lock into place. When both sides are in place, simply drop the car seat on to top of the two attachments. Removal of the car seat is by using the red handles.
HTH..
Nov 10, 2008 | Jane Powertwin Jogger
Pulling down the back seat
should be 2 cloth handles pull them both at the same time
Jun 21, 2008 | 2000 Pontiac Grand Am GT
G5 Handles on plates
called salton and ordered new handles for the plates
Mar 26, 2008 | George Foreman G5 Indoor Grill
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
