The file a3d.dll on windows driver cabinet is needed
Just visit this site...
http://www.fix-all-dll-errors.com/a3d.dll/
this will help in case of missing or downloading dll's .
helped in my problem. :)
Posted on Mar 11, 2011
Sensapi.dll error
How to Fix Sensapi.dll ErrorsImportant: Do not download sensapi.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of sensapi.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the sensapi.dll error.
  1. Restore sensapi.dll from the Recycle Bin. The easiest possible cause of a "missing" sensapi.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted sensapi.dll but you've already emptied the Recycle Bin, you may be able to recover sensapi.dll with a free file recovery program.
    Important: Recovering a deleted copy of sensapi.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some sensapi.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the sensapi.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the sensapi.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the sensapi.dll file. If the sensapi.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the sensapi.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to sensapi.dll. If, for example, you're receiving a "The file sensapi.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The sensapi.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if sensapi.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the sensapi.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The sensapi.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause sensapi.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual sensapi.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair sensapi.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid sensapi.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the sensapi.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the sensapi.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any sensapi.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The sensapi.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Feb 11, 2012 | HP Pavilion Dv9910us Notebook PC
Tip
Cannot Print from Internet Explorer
Issue: Cannot Print from Internet Explorer
Symptoms : When you attempt to print a document or look at it in print preview, you may receive the following error message:
Line: 539
Char: 2
Error: Invalid argument.
Code: 0 URL: res://C:WINDOWSSYSTEMSHDOCLC.DLL/preview.dlg
CAUSE : This issue can occur if the Iepeers.dll file is corrupted or is the incorrect version
Resolution: To resolve this issue, replace the Iepeers.dll file. To do this, follow these steps:
1. Restart the computer in MS-DOS mode or with a startup disk.
a. For Windows 98 and Windows 95 , click Start, click Shut Down, click Restart the computer in MS-DOS mode, and then click Yes.
b. For Windows Millennium Edition (Me), use a Windows Me startup disk and click Start Computer without CD-ROM Support.
For additional information about how to create a Windows Me startup disk, click the article number below to view the article in the Microsoft Knowledge Base:
267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me
2. Type the following commands, pressing ENTER after each command:
c:
cdwindowssystem
ren IEPEERS.dll IEPEERS.old
exit
3. Extract a new copy of the Iepeers.dll file to the WindowsSystem folder. You can extract the Iepeers.dll file from the following location:
The IE_5.cab cabinet file included with Internet Explorer 5.5 for Windows 98.
4. Register the Iepeers.dll file. To do this, click Start, point to Run, and then type the following line:
regsvr32 IEPEERS.DLL
5. Click OK.
6. Restart your computer normally.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
When trying to run the drfagment or Msconfig, I recieve messages that I am missing file MFC42u.dll
try sfc /scannow If still no go, try copying file from C:\windows\system32\dllcache to c:\windows\system32
Jan 21, 2011 | Dell Dimension 1100 PC Desktop
Hello i have a ati radeon 9250 and windows 7 it havent driver for windows 7 therefor i installed driver for windows xp in windows 7 all work good but in shutdown or restart i have blue screen...
The way to fix ATI2DVAG.dll errors is to first restart your PC into "Safe Mode With Networking". This will basically allow your PC to boot up without all the drivers and software which can cause it to crash. To do this, you should first restart your PC and then press F8 continually before Windows loads. After that, you should then select "Safe Mode With Networking" to boot your PC into that mode. When in safe mode, you should download a new version of the ATI Graphics Driver from the Internet, which should fix most of the problems you've been having with it. This can be done by downloading the driver from the ATI website and then re-installing it in Windows.
After updating the driver, try your PC in "normal mode" again to test to see if the problem has been fixed. If you find it hasn't fixed the issue, you should then go back into safe mode an manually replace the ATI2Dvag.dll error on your PC with a fresh copy of the file from the Internet. On top of that, you should also clear out the "registry database" of your PC with a registry cleaner. The registry database is a central storage facility for Windows, which basically keeps all the settings and options that Windows needs to use to run inside. This part of your system is very important and used to load up many different DLL files. To ensure no registry errors are causing problems on your system, you should download a registry cleaner program from the Internet, install it and then let it fix the errors your PC has.
You can fix ATI2Dvag.dll errors on your PC by using the tutorial and tools on our website. You can Click Here to fix ATI2Dvag.dll errors on your PC.
OR
Do not download ati2dvag.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of ati2dvag.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the ati2dvag.dll error.
Restore ati2dvag.dll from the Recycle Bin. The easiest possible cause of a "missing" ati2dvag.dll file is that you've mistakenly deleted it.
If you suspect that you've accidentally deleted ati2dvag.dll but you've already emptied the Recycle Bin, you may be able to recover ati2dvag.dll with a free file recovery program.
Important: Recovering a deleted copy of ati2dvag.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Run a virus/malware scan of your entire system. Some ati2dvag.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the ati2dvag.dll error you're seeing is related to a hostile program that's masquerading as the file.
Use System Restore to undo recent system changes. If you suspect that the ati2dvag.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
Reinstall the program that uses the ati2dvag.dll file. If the ati2dvag.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
Important: Try your best to complete this step. Reinstalling the program that provides the ati2dvag.dll file, if possible, is a likely solution to this DLL error.
Update the drivers for hardware devices that might be related to ati2dvag.dll. If, for example, you're receiving a "The file ati2dvag.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
Note: The ati2dvag.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
Roll back a driver to a previously installed version if ati2dvag.dll errors began after updating a particular hardware device's driver.
Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the ati2dvag.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The ati2dvag.dll file could be included in one of those updates.
Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause ati2dvag.dll errors as they fail.
Repair your installation of Windows. If the individual ati2dvag.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
Use a free registry cleaner to repair ati2dvag.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid ati2dvag.dll registry entries that might be causing the DLL error.
Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the ati2dvag.dll error, this should be your next course of action.
Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the ati2dvag.dll error using a troubleshooting step prior to this one.
Troubleshoot for a hardware problem if any ati2dvag.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | ATI Computers & Internet
Driver stiaspi.dll not found
http://www.fix-all-dll-errors.com/stiaspi.dll/
This will fix the issue without any botheration. :)
May 26, 2009 | AcerScan 620P Flatbed Scanner
How to install audio driver s71216xp?
Uninstall the old driver from device manager. Use the Add Hardware from Control Panel and choose 'Install from a specific location' click next. Use the browse button to point to the .inf file
May 07, 2009 | ASUS P4S333-M (P4S333-M SA/LAN)...
Update the S3 graphics ProSavageDDR
www.soyo.com is your friend:
The page for your board (SY-P4VGM):
http://www.soyo.com/content/Downloads/155/&c=27&p=220&l=English
The win2000/xp driver:
http://www.soyo.com/uploads/downloads/drivers/VIA/s3/p4m266avga_2kxpv139409.exe
Try going to the manufacturer site first, if not found then come to random posting/forums/fixya
Mar 13, 2009 | Soyo SY-P4VGM Motherboard
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
