Question about Texas Instruments TI-83 Plus Calculator
I have to use eng mode. When I type (54.2*10ee-3)*(37*10ee9) I get 2.0054ee11. My teacher says that I should have 2.0054ee3. Does my calculator is broken?
  • Texas Instru... Master
  • 8,025 Answers
No! Your calculator is not broken. However you are not using the EE button correctly, or you are not aware of its meaning.
The EE key is a shortcut for 10 to a power and the 10 is already included.
Here is an example.To enter the [EE] you use [SHIF][,] where the comma [,] is the key between [SIN] and [7] in the column under [MODE]. To enter a negative exponent you use the change sign key (-), the one at the bottom of keypad below 3 and to the right of the decimal mark [.]
To enter 54.2 x10^(-3) you type in 54.2[,] [(-)]3
To enter 37x10^(9) you type in 37[SHIFT] [,]]9
The correct result is 2.0054x10^9 and your calculator will show you 2.0054E9
However by typing in 54.2*10[EE]-3 your are in fact entering 54.2x10x10^(-3) and by typing 37*10[EE]9 you are entering 37*10*10^9 and your final result is in fact multiplied by 100, hence the value you are getting 2.0054E11
Posted on Aug 29, 2010
  • k24674 Aug 29, 2010
    OOPS
    54.2[,] [(-)]3 should be 54.2 [SHIFT[,] [(-)]3
  • johnnybee1 Aug 29, 2010
    Yes, we got the same thing now. We just realize something. THe result is in Becquerel and we have to put it in Megabecquerel. That's why the teacher got 2.0054EE3 :) tnx!
There is an eng sign on my calci, i want to remove it.
Reset calculator to default settings.
Press [SHIFT][CLR][2](Mode)[=], the ENG display mode will be set to OFF.
Oct 06, 2013 | Casio FX991MS Scientific Calculator
How do i clear the eng. function?
Your calculator's display is set to engineering notation, where the exponents of ten are always a multiple of three. Such calculators usually have at least three display formats: engineering, scientific, and fixed decimal.
Depending on the calculator, there are keys (or shifted keys) marked "FIX", "SCI", and "ENG", or a mode setting to change the display format. Use the key or mode setting to change the display mode to one of your liking.
If you need further assistance, please feel free to reply to this post and specify the make and model of your calculator.
Aug 10, 2012 | Office Equipment & Supplies
How to cancel fix mode
If your calculator has a mode key, try pressing it repeatedly and see what is displayed. If you see FIX, SCI, ENG, Float or NORM, press the key corresponding to float or Norm (if there is no float).
If your calculator has a key next to which is the FIX marking, look around to see if you can find SCI, ENG, Float or NORM. Select Float or Norm
Jul 30, 2012 | Office Equipment & Supplies
Using inverse cosign and inverse sin always bring up domain errrors. For example, I used the equation COS -1(185 / -20) . And it always came up with domain error. This is the same equation my teacher gave...
Make sure your calculator is in degree mode.
It is probably in radian mode so it can't calculate the inverse sin.
To change this, go to Mode -> Deg.
Hope this helps, cheers!
Mar 06, 2011 | Texas Instruments TI-30 XIIS Calculator
How do you calculate correlation through the calculator?
You can get the correlation coefficient by using the 2ND STAT key and entering data as shown and then a results screen is shown which should contain what you want.
http://education.ti.com/downloads/guidebooks/scientific/34ii/34iiqrg-eng.pdf
Feb 21, 2011 | Texas Instruments TI-34II Teacher Kit...
How to get the symbol i or imaginary number in scientific calculator
Assuming you're in the complex mode, SHIFT ENG. The ENG key is above the 8.
Sep 13, 2010 | Casio FX-115ES Scientific Calculator
When I type a problem into the TI84 it will give me the answer with an Error. Example, I type in 2+2 and get 4E0. This happens with everything I enter into the calculator. How to I fix this?
Sorry, but it takes sometime to be well familiar with the calculator. The E in the result is a short-hand notation for times 10 to a power. What you got is 4x10^(0) which is just 4.
Your calculator is doing that because it is configured to display result in SCIENTIFIC format.
To revert to the format you may be more accustomed to,
  1. Press the [MODE] key
  2. The first line of the displayed screen will show NORMAL SCI ENG and the cursor blinking on SCI or ENG.
  3. Use the left arrow to highlight NORMAL and press ENTER.
  4. Press [2nd][MODE] to (QUIT) and go to main calculator screen.
Aug 25, 2010 | Texas Instruments TI-84 Plus Calculator
Anything I type in I get A number with an exponent!
that must be because you calculator is in scientific/eng mode. press [MODE], then select normal.
May 07, 2009 | Texas Instruments TI-83 Plus Calculator
Sentry Graphing Calculator ca753
to clear the BASE-N display off the CA756 Sentry graphing calculator press [mode] and [+]
Jun 08, 2008 | Sentry CA 756 Calculator
Texas Instruments TI-83 Plus Calculator Logo
50 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
