Medion fan runs loud and a lot. Had a guy out before and he re set it to run at a higher temp. we had to re set to default this week and fan is going mad and loud again, does anyone know what he went into I vaguely remember him saying about setting to kick in at higher temp 60 rings a bell but I could be wrong
    President:
  • 778 Answers
The fan is probably running at high speed because the Case or Processor are overheating (you didn't mention which fan it it) and that is what the fan is supposed to do, and setting it to rev. higher at a higher temp is only going to shorten the life of your unit.
Why not clean the dust from your heat syncs, boards, and fans? As dust is usually the culprit causing the high temperature in the first place, and is 10 to 20 times worse in a smoking environment.
Posted on May 07, 2008
Noticed temp gauge running a little higher than normal.cooling fans turn on and off very quickly. turned on ac and the fans run. trying to diagnose without getting taken to the cleaners from the...
Check your coolant levels. If the temperature isn't much higher than normal, you may be fine, or you may have a Coolant Temperature Sensor going bad, and reporting the incorrect temperature. Even though the thermostat was replaced 8 months ago, it is possible it is already going bad again. I believe this is more of a Coolant Temp. Sensor fault though. The cooling fans are On when the AC is on. With the AC off, the cooling fans come on when the engine reaches a certain temperature, and cut off once the temperature is back in range. The Coolant Temperature sensor shouldn't cost much, and is easy to replace. I would start with that, top it off with coolant, and then maybe change the thermostat.
Mar 14, 2011 | Chevrolet Impala Cars & Trucks
My car goes to temps up to 220 on streets before it begins to drop to 192 is there a problem.
no i dont think so ,nothing much unless you put a lower temp setting thermostat in like a 82?c ,if it runs ok leave well alone and dont listen to bar room mechanics
Oct 04, 2010 | 1999 Cadillac DeVille
My 2003 suburban seems to run at a higher rpm.
Hummm, 2000 rpm does not seem high, really. But another item to look at is your FAN. The clutch fan fails and drives the fan full engauge. Sounds like a jeep...massive sounding, relating to engine RPM, but not necessarily different.
I mentiont his because a trans does not typically fail and give a few hundred RPM. Usually a slipping sensation is described....
Jul 12, 2010 | 2003 Chevrolet Suburban 1500
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Will run for about 5 mins then fan will stop
It is OK for them to stop, a lot of cars get the fans going as a default, then once the computer checks everything, the engine temp is still low, the fans will shut off, and come back on when needed. Keep an eye on the temp gauge, and notice that the fans will come on when you stop at a light. Or city driving, they should never come on when cruising. And a lot of times they will run after you shut the car off. Just till the temp drops. Hope this helps.
Mar 21, 2010 | 2002 Mercedes-Benz C-Class
TEMP DISPLAY AND FAN NOT WORKING
i have the same problem--i havent replaced the fan--but was considering the control board--have you replaced or cheked this yet?
Aug 01, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Gateway 831GM Eratic Fan Noise
This can be caused by several things:
1. Bad temp sensor
2. Bad voltage, but that will usually cause the whole system to restart
3. Too low maximum temp setting inside the chassis(setting is in bios), often denote as max case temp.
One way to bypass the problem is rig the fan to a molex adapter with a variable voltage molex to 2/3/4pin fan connector and adjust the speed to the maximum quiet setting.
The 831's did run a bit warm so if the case temp setting is set to low it will fluxuate quite a bit. Try adjusting the max case temp up around 50c just to see if that does it, if it does either use the variable voltage dial solution or add a second case fan that's always on, prefferably a low RPM running direct off molex so it will reduce the average temp and therby the need of the monitored case fan to rev up.
Chris
Armor-IT
Apr 24, 2009 | Gateway 831GM PC Desktop
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Computers & Internet Logo
233 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
