Is there anything I can do to print closer to the top of the page? Even when I have my top margin set to zero it starts printing an inch from the top. I have it set to center on the page. In print preview it looks great but when it prints it is centered between the bottom and one inch from the top.
  • 629 Answers
If you print web pages, click File, then click Page Setup, from there, adjust the top margin. Do the same on the application you are using for the document or file you are working on.
Posted on Aug 29, 2010
MG6120 printer starts printing 2 inches from top of page
I want to say it stems from whatever program you are using the print. My guess would be your margins are set two inches from the top. If that's what it is it is easily correctable. You just have to check your margins and access the number back to one you want to use. Otherwise it could be your nozzle alignment which you may want to run some maintenance and try to fix the nozzle alignment.
Aug 27, 2014 | Canon Pixma MG6120 InkJet Printer
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
http://ulearnoffice.com/word/printing.htm
Thanks,
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
I have a lexmark pro 901 and it suddenly just started to print blank pages. all the ink cartridges were replaced and is full, but is still just print blank pages. what is wrong?
It's because of your page set up.
If you have very small margins this will cause it.
Also Headers and Footers even though you haven't put anything in them
the printer and the word processor will allow for them.
Set up your page with a [or the metric equivalent] margin all round.
Set the Header and Footer margins to zero or remove the ticks.
When you do a printer set up remover the ticks [or however it's shown]
so the Headers and Footers are not included in the printing. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Lexmark Printer Support
Feb 27, 2014 | Lexmark X2250 All-In-One InkJet Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
The machine Is printing without maintaining the margin
The Minimum Allowable Print Margin is 2 Millimeters (0.1 Inch). Even if the Margin is Set to Zero (0), 2 Millimeters Will be Added
Mar 05, 2011 | Xerox DocuColor 3535 Copier
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
94 people viewed this question
k24674
jasbo
jasbo
