Question about Refrigerators
Ice Maker not going through complete cycle
Our "in freezer" ice maker stopped going through the complete ice making cycle. The feeler arm is down and not blocked. It makes ice, so I know it's getting water. If I gently pull up on th teeth it will cycle around for the next cycle. But it's not running automatically lik it should.
Any ideas?
  • 1959matt May 07, 2008
    It's just a normal refrigerator/freezer. Freezer on top with the ice maker in the freezer. No dispensers in door. It's 10 or more years old.
GE Model TBX21JPA
Posted on May 08, 2008
    Scholar:
  • 150 Answers
What kind of unit is it? there are several possibilities
Posted on May 07, 2008
  • andrew kinslow May 07, 2008
    ok let me be specific what kind means what brand. model also helps
Whirlpool ET9FTTXLQ11 EM2327397 ICE MAKER NOT GETTING WATER & WATER DISPENSER INSIDE FRIGERATOR NOT DISPENING WATER. REPLACED WATER INLET VALVE IN BACK. ICE MAKER KEEPS CYCLEING.
Posted on Mar 28, 2009
Can this ice maker be set to make more ice? And faster?
Icemakers cycle cubes from the air temperature inside the freezer so you can't do much to increase speed except adjust the freezer control colder. As to the bucket not filling, most icemakers have a feeler arm or plastic paddle that is suppose to sense the ice level in the bucket. Make sure the feeler arm or paddle at the bottom is free and no sticking or hitting anything. It needs to move freely ask the icemaker dumps the cubes. If your refrigerator is less that a year old it should be under warranty and a free repair to you.
Apr 30, 2015 | Samsung RF4267HARS Stainless Steel French...
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
The swing arm gets stuck behing the ice bucket and the drawyer won't open
Swing arm alignment can be restored by resetting the ice maker. There is a reset on the bottom, near the front of the ice maker. HOLD it down through a complete cycle, about 8 seconds, then wait for the two-tone chime to indicate the reset is complete. Failing that, a new ice maker may be needed, the old one may need thawing or there is debris under the bin or arm stopping the cycle. I have actually tore this thing off by opening the freezer at the the exact moment it was cycling too, arrrrgh.
Jul 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Sep 05, 2009 | Kenmore Refrigerators
Feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
May 11, 2009 | Refrigerators
AMANA FRIDGE SCD23VBW, NEW ICE MAKER WON'T CYCLE
repairs should be performed by an authorized repair technician. D7824706Q complete ice maker should never be advanced manually. the ice maker arm should be in the down position in order to advance. once the inner thermal switch has been satisfied the ice maker motor should advance. the ice maker is damaged and will need to be replaced by the proper ice maker.
Jun 04, 2017 | Refrigerators
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
