Question about Cameras
Keeps saying shutter is closed when it is not and screen will not lightup
Bought another camcorder as it is cheaper than paying Sonys repair cost
Posted on May 08, 2008
Camera screen will not light up
The LCD screen maybe faulty.
Take your camera to an Olympus camera repairer for repair.
Apr 06, 2013 | Olympus FE Cameras
The lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
the lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
Jul 19, 2011 | Nikon COOLPIX L12 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
Hi, I would like to take a timed exposer, maybe for as long as five minutes......Thanks
In manual exposure mode, set the shutter speed to bulb. This is the next slower shutter speed past thirty seconds. The bulb setting will keep the shutter open as long as you keep the shutter button pressed.
It's easier if you have a remote control. With the ML-L3 wireless remote, you can press the button once to open the shutter and again to close it. Most wired remotes have a lock so you can lock the shutter open until you want to close it.
Nov 24, 2010 | Nikon D70s Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
The display will not show anything when the camera is turned on. All the options are on the screen but nothing else. It is black.
First off you didn't say if the pictures it is taking are OK, or if they are also black. If the pictures are turning out fine, then it's likely that you just accidentally pressed the DISP or DISPLAY button on the back of your camera, accidentally turning the screen off to save batteries. Press the button one more time to turn it back on.
But if the pictures take are also black, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Apr 04, 2010 | Canon PowerShot A540 Digital Camera
In S mode camera wont take a pic, r09 comes on screen
The r09 is just the display that tells you how many pictures you have in the memory buffer for shooting in continuous mode. There are a few reasons why it might not take a pic in S, but normally it's when it's not in focus. Maybe you have it pointed at something too close for the lens to focus. It also could be that your shutter speed setting is way too fast for the available light.
In S mode, the camera will use your shutter speed setting and adjust the aperature to match the light. If it can't get enough light at the shutter speed set, then it won't expose. Keep in mind this isn't just for exposures that are close to being right, only when the shutter speed is so fast or slow that the exposure isn't in the ballpark.
Try moving your shutter speed up or down.
Jan 03, 2010 | Nikon D80 Digital Camera with 18-55mm Lens
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Canon SD1000 shows black screen when trying to take a picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
