Question about Whirlpool Duet GHW9150P Front Load Washer
Door Bellows The front door bellows seal is broken ,would you please to help me how to replace it? email me at ben.heck@sasktel.net .Thankyou... Ben.
  • 770 Answers
Check you email for the Manual Ben This should help ya
Posted on May 10, 2008
    Genius:
  • 1,073 Answers
Ben it is very complex to replace
Posted on May 09, 2008
With towels we get leaky front door like load is too heavy? does not happen with other loads whirlpool duet sport front loader washer 2 years old. new problem last two months.
Most likely cause is the door seal or proper name for part is door bellows where the door seal to the machine. Check for tears or rips inside the bellows and any cuts where the door meets the seal. The seal could also be pronated toward the inner tub too much just from wear. The seal would need to be replaced. Also make sure the door is locking. The reason it happens with the towels (heavy load) is b/c they put more pressure on the door making it easier to break the water tight seal. Please rate this post.
Dec 14, 2009 | Refrigerators
Whirlpool washer WFW8300SW03 bellows replacement
The following link explains, step-by step, how to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
The following link explains how to replace a door bellow:
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
Unfortunately the service manual will not tell you how to replace the bellows.
Tilt the machine back to create more space between the front on the door and the outer drum. Remove the screws for the kickplate and remove the kickplate for easier access. Open the door and remove the spring clamp holding the bellows to the door opening lip. Push the bellows into the drum to get access to the outside/ rear of the bellows (where it connects to the drum). There you will find another clamp which you loosen/ remove with a socket. Some models have an overfill tube on the top of the bellows (remove it from the bellows). At this point you should be able to completely remove the bellows.
Align the new bellows to the outer tub. Attach and tighten the inner clamp (be careful not to over tighten and periodically check the bellows and clamp placement as you're tightening to make sure it doesn't slip off). Attach the overfill tube (if equipped). Lay the machine back to level and install the front of the bellows to the door opening lip. Re-install the spring clamp by starting at the top and working your way down both sides (may be easier with 2 pairs of hands). Be careful not to overstretch the spring on the clamp.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top. Enjoy clean clothes!
Dec 19, 2008 | Whirlpool GHW9100L Front Load Washer
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
HELLO DANIEL1490,
NGFAM AT YOUR SERVICE!
IF IT IS 1 YEAR OLD ITS IN WARRANTY CALL THE COMPANY THAT MADE IT!! MOST SEALS ARE UNDER WARRANTY LONGER THEN 1 YEAR! ( 5 YEARS)
AND IF IT IS PAST THE WARRANTY BUY A FEW DAYS,WEEKS,OR MONTHS THEY WILL STILL GIVE YOU SATISFACTION IF YOU PERSIST!
ASK FOR A SUPERVISOR!!
I DEAL WITH THIS EVERYDAY AND YOU CAN USUALY GET THME TO REPAIR IT FOR FREE!
THE WATER WAS LEAKING FROM DAY ONE ONLY A DROP AND NOW IT IS GUSHING!
PUSH ALITTLE AND THEY WILL FIX IT FOR FREE!!
HAPPY TO HELP YOU WITH MY EXPERIENCE!
PS. CAN YOU PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF??THANK YOU
Aug 26, 2008 | Whirlpool GHW9400 Front Load Washer
you must remove the large front panel. if you can manage that the rest will become clear to you. dont forget to unscrew the door lock before befor removing the front panel. you will find three screws at the bottom of the front panel under the kick panel, remove them and the front panel will come off.
Aug 18, 2008 | Washing Machines
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal De
